Yeah you can but its alot of paperwork for them to do so most of the time dont bother...But I have also heard once you go back to QLD can pull sticker off as both states dont talk to one another so wouldnt come up on there computers...
But do you live here and havent changed plates over yet?
You probably could be, i guess it would just add paperwork for the officer who defects you
Sorry i cant be much of a help
haha why did you answer
I lived in sydney with Qld plates for 4 months and was never really a target for police.
If you are staying in a different state for longer then 1-3 months you are supposed to transfer registration.
The way to get around it is to just say you are on holidays.
If you have changed your license to say nsw and stay with a qld rego you will get fined.
I drove around for ages with NSW plates and never got in trouble! I always said I just picked the car up a week ago and they were happy with that....I also got waved through a defect station so maybe the story about the extra paperwrok not being worth thier while is true!
I would say that for one thing to screw over a person who is passing through or just moving to NSW with a defect is not really what the police want but if your car is spastic with defects then well that will depend on the police officer to weather or not the sticker is placed on the window .
simple rules to follow if you have defectible parts and are going to have the police on your arse then get rid of them if they are out of the way and are not like a external wastgat etc then you may be ok . It may help alittle with the out of state lic and rego but it wont get you out of everything .
my two cents ((( andrew)))
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
