I have a set of coilpacks out of a redtop eccs rb20det with 104000kms on it, no loom or igniter, just the coils. They were in working order when taken out of the car.
Located in Adelaide but will post interstate at buyers expense using COD or express post. Not really sure on the going price for used coilpacks these days so Im going to say $200 but I will take the closest offer. Don't be scared to make an offer, as I said I'm not really sure of the going price. These will suit either redtop rb20 found in HR31s and laurels I think? With an adaptor they can be used in just about any skyline.
Contact: Send me a PM, Im on here most days or call 0423 277 771
I don't have any pictures but I can get some on request.
Will these fit into an RB20det silver top??? And what is the adaptor you are talking about???
Also there is ID/code numbers on the coil pakcs could you tell me what the numbers are.
Thanks
They will fit into a silvertop but the plugs wont hook up. They are slightly different to the newer ones. You could probably make something up though, might be possible to get an adaptor.
    • post up screen shots of your injector tables
    • Diagnostic flow for a code 21 says check signal at the ECU pins, on a voltmeter of some kind it should read 0.1V at idle, 0.12V cranking, 0.15-0.25V at 2000 rpm. Check each coil such that +1, -3 is infinite or very high resistance, -3, +2 should do the same. (-1, +3), (+3, -2), (+1, -2), and (-1, +2) should all be somewhere between 0 ohms and high resistance. If you trace the path from the coil pin all the way back to the ECU in the diagram the resistance you measure at the coil vs connected to the harness should be pretty much the same.
    • I have an elite 2500 running an adapter harness on an rb25de neo r34. I took the butterfly out and removed all that junk. But I also went Plus+t at the same time. The butterfly thing works in reverse to the boost solenoid on the Gtt if that makes sense
    • yeh they are 235/45/17 up front and 255/40/17 in the rears. I still didn't get my answer if i can fit a 18x9 up front. I want to get 4 of this and see if they will fit before committing as they didn't see an 18x8 as an option but there is a 18x9.5 also.   Enkei RS05-RR 18x9 35mm ET 5x114.3 75.0 Bore Matte Gunmetal Wheel
    • This. The R34 handbrake icon DOES come up when the brake fluid level is low. You might be sitting right on that threshhold. I have been down this diagnosis path and this was the solution (and it was pretty much as full as your picture is to begin with).
