I have an R33 GTS-t and was wondering was size MT's would fit comfortably?
I know of a set with mags for sale - they are 275/50/15 with 15x6.5in wheels...
my drive tyres are 265/35/18 with 18x9.5in wheels & they just clear the lip under wheel arch (car lowered slightly)
the 275's are a good buy (as wheels this size are hard to pick up too) but don't wanna risk buying them if they don't fit...
does anyone have this size fitted to their R33?
any help would be much appreciated...
https://www.sau.com.au/forums/topic/138071-mickey-thompsons/
255/50/16 are best suited to your car, anything larger would be overtyreing the car. They also fit on 300zx alloy rims. can find them somewhat cheaper. otherwise 235/60/15 to suit a 15" rim.
Is that width doable on a 6.5 inch rim?
Have a drag day this weekend and a mate offered to lend me his 275 MT streets. When I realised my 15 inch rim was 6.5 inch wide I laughed and said thanks for the offer but no thanks.
I thought the 235 would struggle on the 6.5 inch width let alone a 275?
275 are generally 17" in MT anyway. should run 255 on a 7" rim.
The common sizes are as follows, 235/60/15, 255/50/16, 275/40/17
Edited by BezerkR32
yep certainly is - i have seen them up close & there is no doubt about it - a
are 15x6.5in rim with 275/50/15 tyres
I have 275/40/17 MT ET Street Radials and a 17x9 rim. The MT Radials replace Nitto 275/40/17.
With the above size on a GTS25t you will NEED to lip the rear guards if you want minimal/zero neg' camber.
  • 4 weeks later...
Whats the offset of your rims? Im thinking of running the 275s on 33gtr rims which are +30 offset but i doubt they will fit..
    • Hi. Yeah thanks. Car is already at tuners and it staying there to resolve "many" issues they do not like. So it is in a good hands. Getting a good tune on that Nistune ECU too so the car would be good. Just needs a little tune up and love.
    • Probably gonna remove manifold and turbo. I’m not sure if I can get M12 x 1.5 air tight. Could use high temp Loctite 246 or something similar, but I don’t know. Maybe it’s just best to remove everything again and weld an 1/8NPT on there instead.
    • Yeah, saw the ratios, not impressed. Would like the punch I have in the first gears now. With those ratios it won't be the same.  Also want the h pattern gearing, or at least a quiet gear set that don't need to come apart for service each year. Looks like the only "reasonable" way Is a 8hp70 transmission, but where is the fun in that🤷‍♂️
    • Hey mate, really appreciate the help. Have been looking pretty extensively myself and was certain they were retro fitted, but then ended up finding a 4 door with what looks like the same side skirts or at least the closest I’ve seen. The photos from the Offset Kings event at Sunrise 2016. https://fatlace.com/offset-kings-okayama-at-sunrise/
    • Isn't there a PAR engineering gearset that has closer to stock ratios? And they claim they'll do whatever ratios you want.
