Duncan,
I assume my slicks are not allowed? If not I will need some rubber for the event. I would like to drive bathurst, its a once off occasion. How much drive time do you get?
  • Replies 86
Duncan,
slicks are allowed. just means you compete in Type 4
its definitely an event worth doing. last year we got 5 runs of the Conrod Supersprint and 4 runs at the Mountain Straight Hillclimb.
Good idea Chris
Also, ill be coming up but not driving (someone lend me their car for a run?) the event, has someone organised accomodation?
If so, ill come up and do the pub thing with you lot, otherwise ill leave Sydney early Sunday and head up :P
Duncan,
Paul,what Harry said is correct,,,but running slicks anyway is not a great idea. You won't get any heat in to them and you would be much better off running semi's mate.
You will enjoy the weekend though.
Neil.
Cant make sunday - in the office - and spewing you cant make it Jon :rolleyes:
for those who have entered - theres my thread in the other section - just post there so we can get a list of who is coming etc
My application for a leave pass was refused, apparently we have to look after Zane's little girl for the night and apparently being 35 weeks pregnant means you have to have your husband round for moral support. Enjoy yourselves!
hey a live in bathurst and will be up there all weekend with my friends racing there 200sx, should be unreal weekend, there was a hill climb last weekend and was great to watch, some bloke in a open wheeler broke the record for thrn weekend with a 21 something...
dam quick..
feel free to come up and say hi
dam quick..
I'll be up there too but won't have the skyline cause of the tree, hope to have it back on the road in january so i can drive on the cruise we are trying to organise.... just hope the council pays for the repairs.... i'll bring up some photos to show you kane. But it looks like it'll take a while for them to decide whether they pay for the repairs or if it goes to court. :(
Neil was up there competing in the capri too, and a local GTR was entered as well, it was a good weekend with a huge field (150 entrants!). Crap weather on fridy night tho!
It was an interesting competition for outright class, Gumley has won the last few years and did hold the record, 22.81....but over the weekend 4 people went under the record, pretty amazing.
And the $300k specialist car that flew out from the UK didn't take the win :whistling: It was a local F3000 car instead....21.62!
yeh that gtr was mad.. anyone know what mods he has???
yes crap weather friday but not to bad the other days.
also a unreal 260z with 6.6l in it 4wd to heard someone say gtr running gear?????
hahah you probably heard me dribbling crap then! I was under the impression it did have gtr running gear, but they were kind enough to leave the car there overnight so I could roll around underneath.....looks like hilux 4wd drivetrain.
