  • Replies 44
Posted Images
I have a PWR intercooler on my GTR (was already on it when I bought it) and the temps were always nice and stable even in 35c heat.
I deliver PWR radiators and oil coolers on a weekly basis to a radiator bloke in my area and the weld quality is great and they always look tops.
https://www.sau.com.au/forums/topic/138544-pwr-coolers/#findComment-2581299
  • 2 months later...
just thought id follow this thread up with some pics i took of the welds, core etc. on the PWR cooler before it was installed. Overall workmanship is very very good for the price.
Also pretty much a drop in replacement, bar a little trimming here of the front bar. Cheers to the boys down Hyperdrive way for the install too :(
https://www.sau.com.au/forums/topic/138544-pwr-coolers/#findComment-2755757
you guys are paying 1k for intercoolers? wtf?... i dunno how you can justify that lol, they have these tiny 399$ ones in supercheap, mines 2x bigger, its a china cooler and cost 130$, welds look better on it as well.
you guys should already know theres no difference flow wise with intercooler weather they were made in china or made by a "well known" company.
and no, they are not made in aus.
Edited by stÖrmy
https://www.sau.com.au/forums/topic/138544-pwr-coolers/#findComment-2783744
yeah mate china ones are fine if you are making stuff all power, but for people who want good quality, awesome welds and a product that is actually tested and developed then they buy a name brand one. Ones like pwr, plasmaman, hks, trust etc all have better core designs which flow better and keep intake temps lower. Plus if he decieds to smash a big single on their, he know that he will not lose power through dodgey design.
but if you want to keep ur china go right ahead.
https://www.sau.com.au/forums/topic/138544-pwr-coolers/#findComment-2783853
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
