what are the spring rates do u know? These are damper adjustable too?
The site quotes this "This damper is also designed for town use; hence, dampening setting ranges from hard (+4kg/mm) to soft (-4kg/mm)." There are 15 levels of adjustment.
I'm fairly sure spring rate is around 10kg. I have shock-dyno results for these at work, too.
https://www.sau.com.au/forums/topic/138730-sold/#findComment-2583882
good price.... how firm are they do you fell evry bump on the road??? why u selling up? also will they fit a r34 sedan???? sorry for all questions just bought my car not sure what fits!
Edited by rgr34
https://www.sau.com.au/forums/topic/138730-sold/#findComment-2630433
They are reasonably firm, yes, and that's more or less why I'm selling them (ie. the roads around my suburb are equivalent to a minefield). If you can live with a slightly ride, though, you would really have to look very hard to find better enigneered and better handling items.
As far as fitting a sedan, I cannot see why not, but probably best to use the search function in the suspension forum. Can anyone shed any light on the subject?
Edited by oblivo
https://www.sau.com.au/forums/topic/138730-sold/#findComment-2630626
    • I said Garrett style. Not Garrett genuine. And something in the G30 550 range is what you want. Not those pokey little old fashioned T28 sized things. The intake ports in the head are small. There is little benefit in fattening up the runners and leaving ths actual ports small. Just run what you've got. And on the subject of Nistune vs Haltech etc..... You know you can control the transmission with decent standalone ECUs these days, right? No need to keep any of that old Nissan bullshit. Don't get me wrong - I use Nistune on my Neo. But it is a DET, so the number of bodges and workarounds I had to do to make it work in a chassis without ABS, TCS, etc, is quite small compared to the herniated arsehole you will have trying to make it work on a motor that doesn't have some of the things that the turbo ECU wants to see. Just easier to bite the bullet and go aftermarket outright.
    • Hmm. Only when the f**king thing is actually working. Still can't find the leak. And that's with dye being put in the last 3 times!
    • Ok so will run the piping over that radiator and no plenum it is. Put that money towards a Haltech and see what suits. Any ideas something like an elite 2000 or 2500 right? My long term goal is 300kw e85 and manual swap and that’s a dream come true. For now will be 200kw and auto the stock rb25det neo intake isn’t too expensive with throttle body. If I was to have the port matching done, Would that be better than the stock de intake as the det has bigger holes plus has the spots for sensors etc? And suit more long term?  appreciate the advice?
    • You understand AFR is not the only thing that contributes to it pinging yeah? Funnily, what the AFR gauge will tell you when it likely is pinging, is going to make you think things are really safe and good.
