post-8927-1194251027_thumb.jpgpost-8927-1194251051_thumb.jpgpost-8927-1194251040_thumb.jpgpost-8927-1160898615.jpgLooking at selling my GTR with the following details:
R33 GTR Vspec 1995
Black
85,500 Km's
280 awkw
Tinted windows
Car is serviced regularly and only has the best put into it or on it. Following is a list of modifications:
HKS boost controller
HKS pod filters
HKS 264 camshafts
HKS cam gears
Apexi polished front pipe
Hi flow Cat
Full jap exhaust
Apexi Power FC
Apexi RSM
Blitz turbo timer
Gear box upgraded to 1998 spec sleaves and syncros
New water pump
Slotted DBA front discs and new brake pads
New Carbonics clutch
Machined flywheel
18" Advan racing wheels with Falken st615 tyres
Pioneer CD MP3/wma player with 6x9 and 6" splits in the front
This is a very loved and looked after car, selling to clear some debt. Looking for $29,990...all offers considered.
PM for further information
Edited by JEV666
https://www.sau.com.au/forums/topic/138769-sold/
Hi Mate,
I well be in the market for purchasing a GTR sometime November, your price is not exactly what I am looking for, but I well see how your tread goes.
Im located in Melb but I'll be in brissie and Sydney in November.
so I'll keep an I eye on your tread and your asking price, hopefully it changes.
https://www.sau.com.au/forums/topic/138769-sold/#findComment-2606466
  • 3 months later...
  • 3 months later...
  • 1 month later...
  • 4 months later...
  • 3 weeks later...
    • Wanted to add some of my R33 GTST  R34 GTR wheels, 18x9 ET30 with 255/35/R18 PS4S'   BBS RE-V7 029 18x9.5 ET22 with 255/35/R18 PS4S' Needs a bit of camber
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
