  • 1 month later...
I just got my Ps in June and i really wanted a skyline and i was kinda worried about all the cop attention i would get if i got a turbo, also i was short on cash and i couldnt even fork out the extra 2000+ for a gtst. So i bought myself a r33 GTS, it does have the weaker RB20DE engine in it but it still runs good. I do get a bit of cop attention and sometimes theyr asses, one of them was even looking under the front bumper, probs for an intercooler lol. Even tho i sometimes wish i bought myself a gtst, spesh wen i get idiots driving their tricked out rides tryin to drag me, i still have great fun drivin my skyline. It might not be the fastest thing around but its still got some grunt and it is a handfull in the wet, not to mention the apexi exhaust is rlly loud. so id say go for a non turbo, insurance still sucks, $3000 per year with $1800 excesses, but i still love mine and its good fun :) and when you have little experience driving, it might even save ya life wen you feel like being reckless on the road lol.
dun ask lol. i didnt do heaps of research before hand as info was hard to come by and i didnt know a lot about them. i didnt think they were heaps diff but ends up they are a bit. im not fussed on it tho, the car was at a good price and in good nick. there are a few things u gotta be aware off, firstly if your considering modding it, things like wheels are a pain to find cos theyre 4 star not 5 like turbos. ive had a hard time finding good 18" rims for my car, most of them cost $2000+ cos theyr more rare, and also restrictions on parts, things like the diff cant take alot of added power. im no guinius with skylines but owning one teaches u heaps. just make sure u look around heaps. make sure u check out carsales.com.au i found mine there, and also www.jsa.net.au (these cars are all recent imports). hunt around for a good deal but be aware of skylines with under 100,000km on the metre as alot will have been turned back so they catch higher prices, and make sure you get the car checked by someone who knows what theyr doing. even tho these are N/a engines, alot have still been thrashed and treated bad. but i would recomend it for a P plater. its rlly good fun, and lets face it, wack an exhaust on it and its gonna fetch you alot of attention, its great :) ill even take it down to the track for sum fun, see wat i can run down the 1/4 mile, not serious with it obviouslt but its always fun
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
