  • Replies 75
Posted Images
Hey guys, I'm speaking to Paulr33 on the phone now, the VIC crew is still going to this dinner.
They have no idea how to get there, could someone give him (Paul) a call on 0404 846 899 and tell them how to get there.
They are staying at Emu Plains
Thanks
Thanks
I can get someone to help you :happy:
I have asked steveo and adam to see if they can help
Keen to go but got no ride, the pulsar has reshat the radiator... suppose thats what i get for doing a dodgy DIY weld up LOL
SO who wants the pleasure of a back seat bogan ;)
.... anyone anyone.... Beuller beuller......
Start at PYRAMID ST, EMU PLAINS - head towards WATT PL
Continue along LAWSON ST, EMU PLAINS
Turn right at GREAT WESTERN HWY, EMU PLAINS
Turn left at RUSSELL ST, EMU PLAINS
Continue along WESTERN MWY, EMU PLAINS
Continue along CHURCH ST EXIT, HOLROYD
Turn left at CHURCH ST, GRANVILLE
Turn left at GREAT WESTERN HWY, PARRAMATTA
Turn right at MARSDEN ST, PARRAMATTA
Turn right at GEORGE ST, PARRAMATT
Turn left at ANDREW NASH LA, PARRAMATTA
Finish: Stop at ANDREW NASH LA, PARRAMATTA
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
