  • Replies 94
Bunta, Im pretty sure thats what MajorSick meant.
Fri is setup
Sat and Sun is show
so really it does start on the 27th, open to public 28th and 29th
No worries I am just making sure everyone is clear as it read like it was open to everyone on the friday
Paul I belive it is 10am
my skyline will be on show... woo hoo can't wait...
where hasnt ur car been displayed? :)
probably wont go this year. are sau having a display or did that fall through?? who is in it if you are??
they certainly are indeedy. i was in it but had to pull out, should be a quality display :P
I've never displayed my car at salon... EVER
actually i've never even been to autosalon, so i'll be poppig my cherry so to speak.
Most Wanted will have some tuff skylines in there display. :P
SA stand will have some quality cars too
me either LOL
awwww, c'mon man! SAU has a lil display happenin'. 7 cars. Should all go pretty well, I think i've managed to think of everything that needed doing ;) *bites fingernails* hope so...
The best skyline on display will be from Godzilla motorsport.
I saw it the other day and it was nice.... to say the least.
Also had a more expensive motor then the car is worth
is it EASY ST??
cant think anything else...need to get out more
honestly im not a big fan of autosaloon, there is not much to do really.....
but this year should be different...see how it goes
i bet the bottom end alone is worth more than the car itself (that's if it is an OS RB30)
is it EASY ST??
This year will be different because there will be one club at least that is displaying somthing other than rice bombs :)
Most Wanted will have some tuff skylines in there display. :)
hahah i was just yankin ur chain, caus i saw ur car on display at jambo :)
    • http://calfinn.com.au/product/1500kg-standard-trolley-jack-cj-2t-c/1500kg-standard-trolley-jack-cj-2t-c   I have this and fits under a S3 33 GTR with no issues. Purchased in 2009 and not one issue. It was $950 back then. Not cheap but something so important isn’t worth cheaping out on.
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
    • Welcome! New member myself, but I had an R33 back in 2002. Best advice I could give, based on my experience: if you're running the factory turbo, be very conservative with boost. I made the mistake of just fiddling around with the boost controller and cranking the boost for fun, and the end result was my intake pipes popping off frequently from the constant deluge of oil that was being blown into the recirc by the stressed-out turbo, which itself was siphoning oil from the engine and farting it out both sides of its centre bearing (or something to that effect). If I could do it all again, I would have gotten a new turbo and had a tune dialled in professionally and then just left it alone! Funny you mention the metal shavings in the gearbox, as I had the same thing - the probe plug (magnetic drain plug, essentially) would come out caked with shavings. At least it was doing its job. Not sure if that's just sacrificial wear and part of the deal, or if my gearbox was shagged, but I wasn't abusing it. Enjoy the R33 - they're a dying breed, and if they weren't $35k+ on CarSales in Queensland, I might have picked up one of those again, instead of the 370GT I own now (though I'm loving the 370GT, that big 3.7L V6 just hits different).
    • Howdy folks. I owned an R33 back in 2002, which was thoroughly beyond my capacity (financially speaking) to maintain/insure, so we parted ways in 2004. Fast forward 21 years (to literally yesterday, in fact) and I'm now the proud owner of a 2007 V36 370GT. I'm happily surprised by how much power the VQ37VHR makes, compared to the RB25DET, considering the latter is turbocharged. I had planned to add a turbo at some point but I'm on the fence about whether I'll even need it (though I do love the sudden onset of extra torque). Any other 370GT owners around the traps, I'd love to hear about your experiences with this car (good and bad).
    • Perhaps the answer is... more jacks!* *proper jacks must be used.
