Hi people
i did the search and there are alot of good tuners out there but most of the good tuners won't bother with the good old microguess.So i'm after tunners in sydney that really know there shit and are willing to tune my car!!!! it's a microtech lt12s so it's one of the new ones.any ideas???
by the way whats a safe AFR to be at on wide open throttle???
Cheers
anthony
https://www.sau.com.au/forums/topic/140366-microguess/
Hi people
Cheers
anthony
Safe
Up to 10 psi 12.0
Up to 20 psi 11.6
Up to 30 psi 11.2
Where abouts in sydney are u
Edited by MR331307
https://www.sau.com.au/forums/topic/140366-microguess/#findComment-2615154
i dont think AFR has anything to do with boost at all
its purely engine load and exhaust temps
saying 11.5AFR at 10psi means nothing
what if he using a stocker turbo? what if he using a gt42?
they both flow completely different amounts of airflow at 10psi
https://www.sau.com.au/forums/topic/140366-microguess/#findComment-2615433
yea been to hitman he's a little bit pricey had my car on the dyno for anhour and a half and charged me $500
i'll give the other two a call tomorrow
cheers
anthony
No problems
Tell us how you go cause i need mine retuned in a while aswel :)
https://www.sau.com.au/forums/topic/140366-microguess/#findComment-2615628
Well i've booked it into adam at JEM he's a top bloke and always looks after me in terms of price and always fixes everything up before he gets it off the dyno the only thing is that he doesn't really like the good old microtech's.
my car at the moment has an rb20 with the following mods
GT30 turbo .63 rear housing
apexi AVCR
Wallbro fuel pump
GTR injectors
3" zorst
100mm blitz front mount
cam gears
microtech lts12
tial 38mm wastegate
and i'm wanting to run it off 18-19psi
because the motor is untuched internally.
i got a tune in melbourne but shorted out the battery and lost it. And cause of my crap manifold design i was making 231rwkw but that was with boost set at 14psi creeping up to 18psi and that was making 18psi at 7100rpm!!!
so i'm putting the standard manifold back on and welding the wastegate on to it so i can reach 18psi straight off the bat with no creep.
any estimations on power??? by the way the red line is set up to 8400rpm
Cheers
anthony
https://www.sau.com.au/forums/topic/140366-microguess/#findComment-2616705
i would be worried about the walbro pump
they have known baddies and tend to fall off in flow as well
make sure the fuel pressure is watched closely, so it doesnt lean out and go bang. doesnt the microtech save its tune in nvram?
https://www.sau.com.au/forums/topic/140366-microguess/#findComment-2616854
Pretty sure it does. I often disconnected batteries on previous cars with microtech and had no drama's.
Make the effort to drive up to RX Engineering if you want a solid tune. I would. Then again, I have heard really good things about Dave Flood from Sydney.
Oh, if you find its just all too hard, I'll take the LT12 off ya hands if you want and you can go PowerFC. lol
https://www.sau.com.au/forums/topic/140366-microguess/#findComment-2617059
To be honest i don't know what happened i know that the battery shorted out and then the car wouldn't idle and then i got some guy to come down and do a quick tune so i could drive it back to sydney but it was running way to rich he said he had to put in an extra 50% fuel to get it to idle then i think what ever the problem was it fixed itself up because i was only getting 210-220km for a full tank on the highway. The car was running very rich with black smoke and the plugs were fouling so i pulled out 40% of fuel and it drives much much better but i'm not sure on the AFR so i'm not hitting full boost till i get it tuned.
I don't mind the microtechs it's the tunners that don't like them.
and if your talking about dyno dave heared some pretty bad stories about him from a good friend of mind that took his car there.
Cheers
anthony
https://www.sau.com.au/forums/topic/140366-microguess/#findComment-2617107
The stock pump will be fine for 260rwkw - they're $100 second hand, or if you have the old one lying around throw it back in :P
Or, go 044 :D
stock RB20 pump is no way good up to 260rwkw. well not if you want your engine to last. i would suggest a nismo pump. plenty of people like the bosch pumps but they require stuffing around to fit, and i do know of plenty of dead ones out there.
also, what type of injectors are you using? surely not stock ones!
https://www.sau.com.au/forums/topic/140366-microguess/#findComment-2617808
Or, go 044 :D
It's not a GTR.
I actually only just noticed it was an RB20 so maybe my expectations above are a little high.
https://www.sau.com.au/forums/topic/140366-microguess/#findComment-2617809
It's not a GTR.
Oops, didnt know it was RB20 - sorry
https://www.sau.com.au/forums/topic/140366-microguess/#findComment-2617821
I don’t know about “has nothing to do”
Boost pressure behind the inlet valve would play it’s role, as it’s a measure of a combustible gaseous mixture that then has a proportional relation to peak cylinder pressure, a precursor to the exhaust temps you mention, with both of these being wot promotes detonation.
There’s no set AF / Boost though I would think there’s an optimum AF [stoch] then a) as much headroom u wanna add in case of wotever, bad fuel, hot day, good hook up, dieing f.pump and b) tweaking for times of extra requirement like peak torque or if the setup is prone to deto at higher RPM etc.
Requires ratios for your setup, is part of what you pay your tuner for.
My 7c
- M
https://www.sau.com.au/forums/topic/140366-microguess/#findComment-2618482
....... ok = my 2c
https://www.sau.com.au/forums/topic/140366-microguess/#findComment-2618522
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
