Fellas with tiptronic 34's
When doing your cooler install... assuming its a Hybrid/China cooler etc
Did the oil cooler or the fan next to it get in your way at all?
Does the front bar just need a bit of trimming?
Thats pretty much it
when i look down.. i keep thinking its going to have to move somehow
on the 33 i had to remove the fan
any help appreciated
I havent found much in the way of searching.. i apologise if there is a thread.. if so.. point me to it instead.
thanks
It needs some trimming, you may find the SRS impact sensor needs to be relocated about 5cm lower and mounted below the fan. Also I have seen 2 types of fan, one that is flush and mounted integral into the shroud, the other has a big motor sticking right out of it.
Mounted well you can avoid cutting the support and have at least 2mm clearance from the fan and I/C core
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
