plus what type of 400kw u talking about? u could boost spike to make 400kw, u could hit it with a farking 300hp shot of gas. or u could spend to $$$'s and get the power everywhere, not just being a peaky 400kw
i can't believe how wankerfull the '07 crew is :domokun:
a war with a clown indeed joshwa :domokun:
When will people be more like us Shane. They all forget what a real build is.
I think when people work out what a decent twin/triple plate clutch costs, along with a fuel system elaborate enough to supply 400rwkw, they’ll work out quick just what the real costs are for big kw figures, that last more then a few dyno pull's.
haha yeh man, only the people who have gone through the 'proper' build know the actual costs involved.
take ur example of fuel system, a complete system would set u back 3k atleast. thena clutch. then a gearbox. then a diff. axles. cooler, radiator. ecu. ebc. tuning. blah blah blah
rofl i alrady know that mate, i am reaching the finish of my project atm mate.
all i have left is a turbo and high mount manifold, clutch, emu
the point with the rx7= cheaper means to make the same amount of power it would take for a piston engine.
now before people begin to lecture a person, perhaps u should consider, that we are also educated in these matters.
its ova mate.
sell your 'porsche'
and get a rx7
your not gonna change my mind.
there is no debating this mate u cant win
end of debate.
cya l8r
Where did I say it’s my Porsche? I didn’t. I said I could be seen in one.
I’m not out too change your mind on anything. You’re just oblivious to what things cost. Sure, you MIGHT crack 400rwkw, but not without a big gas kit and it’s not going to last very long.
So your “400kw” rx7, really isn’t 400kw at all.
To use a word from someone very un wise.. People just can’t be “educated”.
got that mate, stuff i need (refer to previous statement)
not going for forgies, lol, so dont ask
turbo $2500
manifold $1200
clutch $1200
emu $2000
And thats on the cheap. Arent OS Giken clutch's and the likes still up around $2500 - $3500
thats a bit higher then what i can get the parts for, but most people these days pay retail for most gear.
yeah os twins are around 2.5k new. 1200 is for a jim berry clutch (what ive got to go in the gtr, he said it'll hold me to over 1000hp, it looks like i'll be seeing how real that claim is)
alright...how about get an rx7...find out its not as good as a 34 GTR, then buy a GTR....then buy a Dodge Viper :( haha gotta love vipers
A viper? lol... Yeh they are tough. But I would take the rx7 or the R34 before a Viper.
$3500 for the "and the likes" eg: HKS quds with carbon plates ect.
Jim berry is rather awesome indeed.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
