Ok, I couldn't find anything of value so I thought I would ask how the T70 turbo's go with an RB25 motor?
.82 exhaust size with a 60.5mm front wheel is the one I am looking at.
I am ok with a little lag, ie it starts boosting at 3500rpm.
but do they come on at 5k or something ridiculous?
Not after opinions on the quality of a T70, just what they are like on a 25 please.
https://www.sau.com.au/forums/topic/140893-t70/
My mate one tuned one for a customer rb25det and it made 420rwhp on 19 psi. it made full boost at around 4000rpm
https://www.sau.com.au/forums/topic/140893-t70/#findComment-2624026
that's the answer I was hoping for.
have got 550cc injectors, haltech ecu etc etc, so I figure if I see full boost by 4k and I am making high 200rwkw's, they must be a good "cheaper" turbo then.
cheers
https://www.sau.com.au/forums/topic/140893-t70/#findComment-2624032
420rwhp is about 300rwkw :sick:
cheers
https://www.sau.com.au/forums/topic/140893-t70/#findComment-2624074
assumptions?
Why do you think I am asking the question here?
Got an answer that relates to an answer I got elsewhere that they are pretty good on a 25, but laggy on a 20.
The 20 I speak of made 24orwkw on 19psi.
I plan on running 16psi in the 25 and anything between 250-300 rwkw will be a big jump from 204rwkw that I had last tune.
Saying that, it's more a question about lag.
https://www.sau.com.au/forums/topic/140893-t70/#findComment-2624080
yep thats right boosting at 4800, i had power fc, the usuals no internals, too get it to boost early like 4k you would need a good set of cams. and im now running a gt3040. your better to save your money and do the job right first than waste $500 or however much they are, i learnt the hard way money down the drain and i had a lag monster.
https://www.sau.com.au/forums/topic/140893-t70/#findComment-2624094
gt3040 or a gt3540, is a million times better. you can choose your ex. housing size for your response you want. there excellent quality, ball bearing, water cooled. i really wish i went that to start with instead of trying to get cheap power that just cost more in the end.
https://www.sau.com.au/forums/topic/140893-t70/#findComment-2624119
I had one also on my rb25 and didnt see full boost till about 4800-5000rpm...was a mass lag monster. On 17psi i made 350rwhp with supporting mods and all, no cams though.
then it ceased up cause the shitty oil line i used got blocked up and starved the turbo of oil.
Now have a gt3040 with .63 rear, much much better :)
https://www.sau.com.au/forums/topic/140893-t70/#findComment-2624947
i got a friend who has one of these t70 turbo's off ebay..its making around 293rwkw @ 18psi,bit of a lagg monster but once it comes it comes on HARD..has been for last 5months..never missed a beat..i dont understand how u guys break them so easily?
https://www.sau.com.au/forums/topic/140893-t70/#findComment-2627344
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
