My series 1 R33 GTS-t up until very recently was fairly modified, and the police thought so as well when they pulled me over and gave me a fine, and gave me an invite to the EPA.
I have since decided to make my vehicle more legal, and have taken the car to a workshop to remove some mods, the main ones being the injectors and the Microtech MT8 computer, going back to stock ECU, AFM, etc.
The car when I got it back is very uninspiring, has horrible torque holes, unpredictable power and is generally running poorly. The car has not been dyno tuned yet on the original stock parts, other than tuning by the workshop that changed my car back - but I have noticed a couple of things on the wiring/vacuum hose that I am not sure are quite right. I purchased the car with the Microtech, so it didnt have an AFM or some of the loom wiring- and didn't need it.
Not much point getting it tuned, if something is unplugged that is causing my problems..
Two things seem to be obviously missing:
- There is a prominent plug that looks like it needs something plugged in it about where the throttle butterfly is, going in to a black box. Nothing is plugged in there, and there is definitely no plug in the loom that matches it. Is this supposed to have something there?
- A small vacuum hose is hanging loose with just a screw in it to prevent vacuum loss- This is next to the power steering reservoir, behind the air box. One hose goes to the pressure side of the intake, the other goes nowhere. Where is this supposed to go to?
Any help appreciated.
Thanks,
Alan
https://www.sau.com.au/forums/topic/141110-wiringhoses-on-rb25det-engine/
1. No, see that plug hanging just below it? That's the wiring for that one. Weird but true.
2. I can't see it.
Thanks for that, 1 down, 1 to go :laugh:
Attached is a hopefully easier to see picture...
The red arrow is the gold colured valve part where the hoses are going to.
The blue arrow is where the vacuum/pressure is obtained, this goes on to the valve part, the lower hose point.
The green arrow points to the loose hose with the plug. This goes in to the valve part on the upper hose point, the other end hanging loose..
Sorry for my dodgy terminology, I don't know what it is supposed to be called.
Red Arrow --> Stock boost solenoid (Bleed Valve). Controls boost.
Blue Arrow --> Pressure Side, Pressure flows to the solenoid through this hose.
Green Arrow --> Bleed Hose, any air that is bled off by the solenoid goes through this hose. From factory that hose plumbs back into the "plumb back" pipe coming from the BOV. So any air that is bled off to create more boost, is bled back into the intake before the turbo.
I don't know why that hose is blocked off. Unless your car is using another boost controller.
Because it is blocked off, and if the car is using the stock boost solenoid to control boost, then it would not be able to bleed off any air to increase boost.....so the turbo would only be making 5psi max and not 7psi.
Anyone please correct me if i'm wrong.
Great, thanks for that. This clears things up a bit..
This car did have a boost controller, but no longer. It may not have been put back 'stock' correctly.
The car has been meauring 0.6-0.7 bar of boost (8-10psi) so boost seems high if anything for the stock wastegate.
Since your post, I checked the car, and indeed there was a hose going in to the wastegate return... it was connected via a T piece going in to the 'blue arrow' hose... so we have effectively 1 hose connected to the pressure and the non pressure side, which this solenoid is supposed to measure? It obviously was not doing a great deal, as the pressure goes straight back through the return. If effect, the solenoid would never be told that the pressure was too high, it would always be measuring lower than boost pressure.
I think this T piece used to go to the the boost controller, but was just plumbed back wrongly.
I have disconnected the T piece, and have replumbed 'green arrow' hose back to the wastegate return, and directly attached the 'blue arrow' pressure side to the solenoid. It looks neater now at least. :)
I took the car for a drive, and it didn't make it any worse, but didn't make it any better either. Boost in unchanged at 0.6-0.7 bar, power is erratic. I guess it is time for the dyno tune...
    • I sense an out of control build thread coming up lololol. That 450kW goal will end up being 600 to 700kW LOL.
    • Nice, thanks for sharing your progress....that's a pretty long list you are putting into it!
    • Decided to upgrade my pressurised plastic coolant expansion tank for a fancy pants alloy version The OEM versions can get brittle, even the new plastic one I got when I first got the car is a starting to show signs of "stress" I wasn't cheap, but it is basically unbreakable
    • Morning all, I have an RB25DET Neo that's in need of a rebuild. Will need new pistons etc due to detonation damage. Would anyone be able to recommend a shop in Southeast Queensland who I could bring my long motor to for a rebuild? Just want someone who knows RBs and whos built a bunch of them before. TLDR - recommended engine shops for RB rebuild.
    • Gday Thought it was about time I started a build thread! As expected this project has snowballed into a huge financial liability, but unless you’re strong willed and responsible, it’s not a surprise. Background -  My first turbo car was an R32 GTS-4, got my full license and then totalled my Au Falcon a week later, so while trying to sell my RMZ450 dirtbike to buy another car a bloke offered to swap the R32 which at the time I felt like I was ripped off but looking back and seeing prices of those now ($40kish) it was a good deal, I didn’t know enough about these cars to appreciate what I had so sold it before the RB20 blew up. Between here and there, out of 12 cars I’ve owned the note worthy ones are a V8 Lexus SC400 (soarer), a couple of XR6 Turbos and my beloved S15 which I had for about 3 years, picked it up for $12500, repairable write off but she was fine, gun metal grey/pewter and bone stock/unmolested until I got my hands on it. Ended up spending about the value of the car and 280kw, 2 demerit points by the time I got defected and sold it for $14500 (also $40kish in today’s market, rip) Fast forward to the present day, I’m in a much better position financially and daily an MQ Triton (great cars, pipe down Ranger Bois), I cruised marketplace and car sales for a few months looking for another R32, the best deal I could find was an absolute rust bucket half finished project for $12000, until this R33 popped up in Port Macquarie for $18k - unregistered and barely running but decent shape, kept an eye on it for a few weeks and the price steadily dropped, $16k then $15k then $14k, that was the point where I was like shit someone’s gonna snatch this up! It was owned by a young bloke who had big plans but him and his missus just had a baby so smartest move financially for them but big gain for me. So 2 days later I’m towing a car trailer to pick this thing up. Roughly 2 weeks and $3500 later I’m cruising around Newcastle in my beat up R33 all smiles and dose noises! It only needed some basic shit to get it going, coil packs and air flow meter, electrical stuff and all fluids changed, 158k kms and running pretty good, nice smooth engine after oil and coolant flush - when I say coolant I mean it had been filled up with tap water, every gallery and heater element was filled with rust, 8-9 flushes later and still had brown liquid coming out but she’ll be right. The car was painted R34 Bayside Blue at some point but whether it was a cheap job or just not looked after is anyone’s guess, clear coat flaking like sausage roll.  Was rethinking my choices and contemplating life, had it up for sale for $22k - still cheaper than any registered R33 but got little interest, next minute I had an opportunity at work - 6 months overseas for good money, so that was a no brainer, fast forward again and here we are with a 50% finished project. Current Mods - 200ish KW according to butt dyno Was tuned with Apexi PowerFC EBC (old school Greddy Profec)  Stock turbo (more shaft play than a Tinder date gone right) 3inch turbo back Varex muffler  Aftermarket injectors of mystery size, Power FC showed 36% duty cycle at full boost so not behd good size Someone had good intentions but stuck with the stock R33 MAF so we had misfires at 6000rpm due to the MAF hitting 5.2V So far I’ve redone the entire interior with carpet form Car Mats Direct, new Seats and steering wheel from Autotechnica, also sound system by Autobarn (mainly Kicker) Also MCA pro comfort coil overs - Hands down best purchase yet, worlds of improvement over the tired 30yrold shocks Goals - 450kw/600hp on flex tune New paint job - Midnight Purple 2 Engine is at the shop getting rebuilt with forged rods a pistons, new valves and springs, ATI Harmonic balancer, Aeroflow 7.5L sump, rear head drain and oil restrictors as per oil control thread* and cam covers modded for larger breathers, other stuff I can’t recall of the top of my head Parts purchased and to be installed once the engine is done -  Engine loom from Wiring Specialties including these options: Haltech Nexus S3 R35 Coil pack conversion  PRP Dual Trigger kit Fan controller  Other Parts -  262 Kelford Cams Turbo - Hypergear ATR43SS3-ProS with T51R mod (whistly boi) 6 boost manifold (high mount) 50mm Turbosmart Pro gate (plumbed back for legal reasons) HKS Super Turbo Exhaust with High Flow Cat Custom 3.5inch dump and front pipe 1500cc Bosch injectors  Fuel Pump walbro 525 Haltech MAP and IAT sensors Haltech Flex Sensor Fenix Radiator with dual thermo fans LS1 Alternator Kit Oil Filter Relocation from EFI solutions and Cooling pro oil cooler Many other things sitting in my garage waiting for that engine to come back. Progress pics to follow -
