Hi all,
I think I may have a buggered clutch but I am wary of being a hypochondriac about it!
Last week I did a 7k launches on GTr with 80k km's, std turbo's, Power Fc, and poncams . This combo made 550Nm and 250rwkw when tuned.
After the launch I returned to the office with a stinky clutch, it was still stinky 5 hours later after a 45min drive home in traffic, yet didnt feel any different to drive. On the weekend I took it out and found that on a hill in 3rd with foot down I saw the front torque swing up to 20 on the gauge. Oops buggered clutch I thought .
But by monday after leaving the car for 2 days, I couldnt repeat it, and last night the worst I could do up a hill in high gears was get the torque split to read 2.9.
So have I really stuffed my clutch or did I perhaps have some oil on the friction material that has now burnt off?
What do others see on the MFD torque monitor when driving vigorously (vs clutch dumps)?
Cheers & thanks
Ned
Standard clutch? Mine looked ok when I pulled it out but i never did think they were good clutches. How many K's on it?
Even if your clutch is fine I'd be upgrading. A nismo super coppermix twin plate is a superb clutch for the car. I've got one in mine as well as many friends with GTRs. As does the Nismo Z-tune (albeit the beefier one)...
Hi there Sewid,
the clutch has ~80k km's so is getting near its useful life. I commute in the car so ease of use is high on the requirememt list, how is the coppermix?
I have th eoption of OS giken twin plates, a rebuilt strengthened single, or a Nismo Gmax (not coppermax), which would you take? it might be nice to have the oiption of some high rev launches but mainly its enthusiatsic driving that would be the key with docile city driving most important.
Cheers
Ned
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
