Im in a position where i have financial difficulties due to some unforseen circumstances, thus the R34 which i only recently bought is actually up for sale already! Im willing to cop a loss as I cant afford to keep the car at this point in time.
Mods:
* Bullet titanium cat back exhaust
* Mild steel front/dump pipe
* High flowed cat
* Lowered springs on KYB shocks, approx 2.5inch all the way round
* Apexi power intake air filter
* Hybrid tube & fin intercooler
* 3 puck heavy duty brass button clutch (You wont slip with this baby )
* Full 3 point alarm with imoboliser, and turbo timer
* Blaupunkt CD player
* Pioneer 2way speakers front and rear
* Apexi Power FC (No hand control)
* Factory xenon lights
* White LED parker lights
* Replaced castor bushes
* Clear indicators
* Factory GTT wheels painted in black
Power: 204rwkw @12psi / 545nm of torque! THIS THING IS DAM QUICK! So grab yourself a bargain, while i have to cut my losses and move on. Pictures wont justify how nice the car actually is, so get in quick!
Rego: Till september 2007
Contact: Jason on [email protected] / 0423 324 906
Price: $26,000!
NO TRADES
BONUS: Now comes with BLITZ ID3 & pair of HKS coilovers!
Edited by Mr_G
https://www.sau.com.au/forums/topic/141170-r34-gtt-quick-sale/
just to confirm the car comes with the black rims? not the ones in the first couple of pics?
Car comes with the black rims in the photos, not the silver ones. Silver ones are now owned by my dad on his R33 :P lol...
Thanks for the props Porko :rofl:
Now comes with the blitz ID3 boost controller!!!! Get in quick :) Today was quite warm and the car still had grunt behind it even on the warm days.
When i went to check out R34's, this was definately probably the healthiest mechanical R34 i found to be honest. Just come check out the car for yourself, you wont be disapointed with the package it offers.
this is not very fair lol
if you were in brissy i would of prob jumped on this lol
awsome looking car sounds a dream.
definatly worth it i think anyway
hope sale goes all well
