As topic says i have some nismo 600cc injectors for sale. Bought them off GKTech(sponsor) a few months ago but plans have changed and i need the cash. My loss is your gain! Prior to buying these they were flowed and cleaned and are as good as new as seen from the pics. I have taken 2 out of the package for some quick snaps but the rest are still wrapped up (i assume they were packaged after they were cleaned etc). I havent touched them since i bought them, they have not gone near my car.
Price drop; $600
Can contact me on 0422069596 or through pm
Located in Northern Suburbs, Melb.
Cheers!
GKTech's original thread can be seen here
pics;
tn_gallery_17352_1444_214452.jpgtn_gallery_17352_1444_85412.jpgtn_gallery_17352_1444_84074.jpgtn_gallery_17352_1444_130373.jpgtn_gallery_17352_1444_159236.jpgtn_gallery_17352_1444_46637.jpg
https://www.sau.com.au/forums/topic/141297-nismo-600cc-injectors/
