That sounds damned excellent. I get around 370 around town before I fill up (~50 litres or so) and get 500-600 or a little more on the freeway depending on if I fill up when the gauge reads empty or if I let it run till it's almost bone dry.
I consider my car to be pretty light on fuel (13.5-15L/100km around town, 9.5-10.5L/100km on freeway) especially given its power output (~200rwkw) so your figures are pretty darned good.
https://www.sau.com.au/forums/topic/14171-fuel-consumption/#findComment-285101
The most efficient car you can get will use around half the fuel of the Skyline. That's like a Daihatsu Charade or something. If you reckon that it will only cost you $30 per week to run the second car, as in pay for it, insurance, registration, maintenance, repairs, etc, then you will only just break even. I guess then you'll save some depreciation on the Skyline, but would it really be worthwhile?
If you were going to do that you may as well get a motorcycle. At least then you'd have something a little different and a lot cooler than a Charade :D
https://www.sau.com.au/forums/topic/14171-fuel-consumption/#findComment-286178
    • The speedo's can be very conservative, when my Mazda NC MX5 speedo is showing 118kph, the GPS, and a calibrated radar.... cop mate.....hits me at around 110kph +/- 1 or 2 kph, and that is on a 215/45 17, stock tyres size is 205/45 17 as well, so weirdly conservative with stock tyre size When my Commodore speedo red 116kph GPS had me at 110kph After doing some offset and clearance measurements to see what can fit the NC on 17x8 +40, without guard rolling or rubbing anything at my current ride height, I've decided that when my tyres are toast, I'm going to fit 225/45 17 and see where that gets me IRT actual speed of my speedo and GPS/radar From the online calculator I should be still be doing around 5kph under an actual 110kph when the speedo is showing 110kph My ADHD requires that when I'm doing 110kph on the speedo, that the actual road speed is actually really close to that, and not alot slower And going from 205 to 225 still keeps the car within the %/mm allowable in the NSW vehicle rules and regulations, which is nice, as long as I'm looking at the latest version that is.....LOL https://www.nsw.gov.au/sites/default/files/2021-02/RMS-13.464-Light-vehicle-modifications-Vehicle-Standards-Information-No-6-November-2013.pdf
    • Take the value it measured as, and pick the closest range available that is above the reading on the screen.   Also, no point just testing the coils. Read what has been said again. You need to test all your wiring, everything.
    • Does the scanner do all the CUs in the car, or only the ECU?
    • @666DAN sorry to bring you and old thread.     I've got my de+t done and it's all running great other than 1 small issue.    Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd when selected . But nothing when in  drive or what gear your in when you pop it into tiptronic. I'm sure there is maybe 1 wire in the ecu plug I need to move to rectify this. Do ya have any ideas?     Cheers man
    • Well I recently changed my rear axles and was thinking if I bumped anything, I have been driving the car for a while now though... But it has been raining today so everything is wet under the wheel arches. Brakes feel fine and can't hear any of the metal screamers, I had a squeak coming from one of the handbrake drums but that seems to have gone away a while ago. I was going down a hill when it lit up and I did feel the abs bite for a second and question why it did it?
