Just curious ive got a set of new lines with my hks turbo all turbo fittings, the problem lies with the existing ld rb25 turbo piping, the two connections coming out of the block im assuming you need new block fittings for these, if so what ones do i get to suit my new lines (Braided oil line and also silicon water line) the same kit you get off gcg. Hope you guys can help me out.
Cheers Adam
Also on a quick note what exhaust studs are needed for rb25 exhaust manifold, if possible a repco part number would be great
Thankyou
Edited by Devils_Advocate21
https://www.sau.com.au/forums/topic/141974-turbo-oil-water-lines/
The gcg one looks to come with all the fittings you need. The last set of hks ones i installed used a standard size banjo fitting for the block end of the lines.
The exhaust studs are an m8 1.25 pitch 50mm long from memory. Try auto one. They usually have a box of exhaust studs under the front desk.
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
