Rda Rotors Group Buy - 5th & 6th Batches
Received my rotors today. Just want to double check that the rear rotors are the same for R33 GTSt and 300ZX TT which is what is marked on the box? :S
Yes, All 300ZX TT uses the same rear rotors as R33 GTS-t (Part no 908) - they are interchangeable.
  • Replies 113
Allright guys, for batch #6:
1. RB_n00b - R33 gtst full set 7693S & 908S rotors - payment received
2. Simonster - R32 late GTR front 7701S rotors - payment received
Just to make it clear how this work: I do not work for RDA, and I do not personally send the rotors to you. (I don't even get to see the rotors.)
I submit the combined order to RDA (as an SAU Group order), and they do all the delivery and arrange where and which warehouse they got the stock in.
I believe when it comes to shipping RDA do it in one whole batch of all of you (logically they should be doing it that way to avoid confusion). So if the others have received theirs, it's just a matter of days before they get to you. As you've given me your daytime contact (mobile) it should have been written down on the delivery docket too so the courier can call you if no one was home.
But if yours haven't turned up in the next few days I will follow up with RDA - from the past 4 batches usually it's because no one was home and the courier could not get call the recipient (phone not provided, wrong phone number supplied, not picked up, etc).
I'm still waiting for a couple more transfers to go through, some said are transferring tomorrow as well, so looks like at least monday or tuesday for me to submit the order. It's a lot easier if I submit the order for 5 or 6 people in one go, rather than 3 tomorrow, then 3 on Monday...
Some transfer (e.g. electronic from other banks) may take 2 days to appear that's another reason for me to wait...
Monday evning update:
3. alexk - R32 GTR front 7926G & rear 908G - payment received
4. Fra22 - R33 Gtst front 7693S - payment received
5. xolent (welcome back) - 7500S & 478S - payment received
6. babia - R33 gtst rear 908S rotors - payment received.
7. IanB - R32 GTR (early) - pending payment
8. Deceeve - R33 Gts-t 7693S - payment received
To prevent delays to others who have their payments cleared, Group Buy #6 is now closed.
Batch # 6 will be submitted some time tomorrow afternoon. Will give you guys update in this thread tomorrow...
    • Yes that’s what im trying to decide. Should I do stock gtt box or enclosed or open pod.
    • Also, I note OP is in Melbourne, which begs the question... are you aware of how illegal your car will be with a turbo, and intercooler and any sort of filter change? I don't know how you can get past the "2 intake mods" "rule" that seems to exist in Vic. Fully engineered might or might not get you there.
    • If you have a turbo... then the ducting holes I used to feed the pod are not available because your intercooler likely uses them. If you have an intercooler, your IAT's are going to be goverened by how good your intercooler setup is. I'm yet to really see anyone check IAT with a snorkel/boxed pod/proper CAI versus and unshielded pod. It would be interesting! But I suspect that the differences would not be so noticeable as if you were N/A as the intercooler is where the air is being cooled.. and out in front where the FMIC would be is a pretty good spot for it.. When I was turbo I pushed the stock GTT box as far as I could and made some pretty good power out of it, and noticed on the street I never made the same power/boost. Then I did a before and after run with a pod filter versus the box and picked up about 9PSI from the same boost duty cycle and about 50KW instantly. I never ran the stock box again, and recently removed it for my N/A setup. The box is restrictive to a degree - Even with the V8 setup I noticed I picked up power by removing the box completely, so punching holes from the bottom of it to get air from the passenger guard *helps* but the most effective one in my case was simply having the ducts, a pod, and no box around it. In my experience, *more* air was better than cold air. The air (with ducts) will be cooled off as you start moving, and especially if you start moving fast (a race track). It actually moves around quite a bit as you can see.
    • Well you could certainly buy or build an enclosure for a pod in that corner of the bay. It is absolutely vital that there is a nice big opening to let cold air in to it from the front or underside, otherwise it will just pull air in around the edges from the bay, and if that air is hot, you gain nothing from enclosing the pod. There is lots of good evidence around (including on here, see posts by @Kinkstaah for example) showing that pods pulling hot air from the bay is only a problem when you're static or slow in traffic, and that as soon as you get the car up and moving the air being grabbed by the pod cools down. Although that will obviously vary from car to car, whether there is a flow of cold air to the pod or if it all has to come through the radiator area, etc etc. Obviously, the whole exercise requires as much thought as anything else does. Doing the lazy thing will often end up being the dumb thing. The stock GTT airbox has a cold air snorkel to feed it from over the radiator. Shows that Nissan were thinking. The GT airbox is upside down compared to the turbo one, yeah? Inlet at the bottom, AFM/exit on the lid? That might make it harder to route the turbo inlet pipe using the GT airbox than a turbo one. That would probably be the main reason I'd consider not using it, not that it is too small and restrictive. I'm looking at a photo of one now and the inlet opening seems nice and large. Also seems to have the same type of snorkel that the turbo one has. Maybe all that's required is to make a less restrictive snorkel/cold air inlet, perhaps by punching down through the guard like I did.
    • Also seen this as an option
