i bought an "autogauge" gauge from "online depot" also for pretty cheap
they provide a good product for cheap, but there is a couple of weeks delay with them..
worth it for the price you pay :whistling:
I'd use a different quote.. "you get what you pay for."
Like a few people in this thread, I bought a black face autogauge meter from the same place.
Prompt delivery and the product looked alright. Hard to see the needle in daylight though.
After a couple of weeks I was bothered by the rest position of the gauge ( reading when engine was off ) plus it was reading about 4 psi on stock gtr actuators.
Scavenged a mechanical test gauge from work and used it as a reference.. was sitting on about 9psi.
Meter was filed in the round filing cabinet..
Ordered an a'pexi mechanical el meter to replace it and am much more confidant of a correct reading.
I wouldn't consider a correct reading gauge a luxury.
James.
  • Replies 45
quick question regarding install
comes with a long length of clear tubing which you attach to rear of gauge then run into engine bay, then there is a short lenth of a larger size tube which you attach to t peice from vacuum line...should i just use the smaller sized tubing all the way or buy some more tubing the same size as t-peice & run that all the way into cabin then use a tiny amount of the clear tubing just to attach to rear of gauge?
Thanks
Noel
Ok installed gauge on weekend...I put it where the ashtray is supposed to be...Just took it out, cut a bit of mdf to fit then cut out hole in middle for gauge, stuck some grey carpet that i had lying around on, put gauge in mdf, it hooked it all up then pushed mdf into space & presto i now have a boost gauge in a legal spot...will post pics when i take some.
Only drama i had was a tiny one where T-peice did not fit original vacuum hose to inlet but i replaced this with left over 4mm hose that i had used instead of the clear nylon tubing that comes with gauge & was all good
Edited by Noel
Here are some pics I took yesterday, with my new camera, of my dash/center console:
Ricey I know lol
Click here for more pics
Its been sent but Aust Post dont know where it is...Mark is chasing it up with them
Received, seems Australia Post magically found it, & it showed up at reception once we enquried about it.
All good its here now so now i can go and play ;-)
Also my turbotech does not have a little pin hole in it...in the original thread for these i saw a few others also had no hole & one was even told its the new design...is this a problem or is it all good?
Cheers
Noel
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
