As topic says i need a s2 r33 afm to borrow! Engine conv is done but it wont start without the s2 afm. Will only need it for 2-3days max! URGENT as i dont want to have to go to the wreckers and pay $220 for one when as soon as the car is running its being sent in to get my wolf installed and tuned which means no need for the afm. Anyone who can help pm me or phone on 0422069596.
Cheers!
https://www.sau.com.au/forums/topic/142597-urgent-s2-r33-afm-needed/
just lemme borrow yours al ;)
Two reasons you you can't borrow mine:
1/ Mine is a S1 afm, and wont work with a S2 engine/ecu package
2/ Matt (Mavric) is currently using my afm and coil packs, as his were stuffed.
If a S1 afm will work, i am sure you can borrow Matt's stuffed one. Car still drives, etc, just cracks the shits intermitantly and you loose power for a few quick second bursts, after hammering it. If you just need to drive to your mechanic, it will definately get you there. Matt had the fault for months and still used the car as a daily driver.
    • I thought it could be an issue because the standard plate was flexing when stressed. Maybe the original gear set will hold a bit better without flex? Last time on the dyno it made around 670nm at the hubs. Now it have bigger turbo and better intake but have not been on a dyno yet. The car is being used from family trips to drag race events. So the shifts can be a little violent. It is grinding if I shift to fast so was thinking I should overhaul it soon.
    • From the factory on RB26s there's a fitting on the intake manifold collector/"plenum" that provides pre-throttle boost signal. That's how they did it back in the day, I figure it's fine to replicate it.
    • I would be surprised if that wasn't the issue. It's probably telling you, that even if you remove the plastic liner, you may have some other clearance issues that may occur too in some scenarios. IE, tyre to guard. It looks like someone has already rolled the lip, but you may still have issues in the future IE, turning and hitting a bump etc. The fact it changes how bad it makes the noise when you are going backward vs forward is highly indicative that it's the tyre rubbing. They do make a terrible sound, even if you're only pushing a project car that has a liner hanging down on a tyre!   Has the car been lowered? If it has been, what is the measurement from the centre of the wheel hub to the lip of the guard straight up?
    • Summernats cruiser?
    • Mark's a bit smarter than people give him credit... He'd convince the person that is to become dead, to drive him to the forest first. That way his car has no evidence in it, and he's free to dispose of their vehicle permanently how he sees fit too...
