Hi guys,
EDIT WILL SELL ALL THREE AMPS FOR $300 MSG ME ASAP IF YOU WANT THEM!!!
Im just doing a clean out of my bottom room and found heeps of stuff to sell.
- Stock R33 Airbox for $50ono - SOLD - PAID
- Slot car set, i think its AFX or something - $60ono
- Kicker IX402 - Not sure wattage but pumped hard in my R33. - $75ono - SOLD - PENDING PAYMENT
- Kicker IX702 - Not sure wattage but pumped hard in my R33. - $90ono - SOLD - PENDING PAYMENT
Will sell both amps for $150
- Fujifilm S3000 - Just got a new camera in the US, this is still an awesome camera just dont have any use for it. - for $90 - SOLD - PENDING PAYMENT
- 2 x LYNX 800VA UPS's - Used one of these to power my whole computer room. - Make me an offer
- I have a f*kload of batterys for sale for $5 each too. All are brand new. (12v UPS batterys, possibly good for car computers so it doesnt flatten skyline batterys)
- Jaycar AMP - 4 x 100RMS or 2 x 380RMS at 4ohm - Im not sure if i want to sell this amp as it is so powerful and produces an awesome sound. So make me an offer. - - SOLD - PENDING PAYMENT
- Numark DJ Mixer - 2 channel, DM950 - for $120 - SOLD - PENDING PAYMENT
If someone wants the lot, make me an offer and i will see.
There is also R33 stock wheels for sale, so if your interested let me know. My PM box is full so either email or post here
[email protected]
Cheers
Edited by sindows
https://www.sau.com.au/forums/topic/142840-fs-heeps-of-stuff-clean-out/
I dont know jack about UPS', is it like this one? (ie 45mins time with 450w?)
Can I add more batteries to make it last longer? Its for my fish tank.
Anyhoo, let me know about price.
what comes with the camera,any extras eg larger storage cards,lenses,tripod,recharger/batteries
have you used it much,any faults
cheers
paul
32Mb and 64Mb cards, has the box it came in. Its not an SLR so it doesnt come with additional lenses and what not.
Its been used but not alot at all. Had it for about a year (mabey a little longer) and used it for about 24-32hours.
No faults, the only reason for selling is becase my mother bought me another one when i went over seas.
LYNX 800VA UPS how much for one..
set me a price on the jaycar amp..
and i'll give you $100 for your numark 2 chan mixer
- $120 for both UPS's Additional Batterys $5 each (they are brand new.)
- $120 for the mixer and its yours.
- Make an offer for the amp.
Yeah how much for the UPS? And do you know its specs?
Not sure of exact specs, its about 800VA but it works alot better than other ones i have had.
I have 2 power boards (with 6 sockets in each) powering, a monitor, comptuer (550W PSU), cordless phone, amplifyed 2.1 speakers, Modem, other chargers, printer and other shit and its lasted about 25mins.
Im sure it would last about 1hour powering a fish tank pump :) or longer :)
Well i have heeps of batterys ($5 each) They are brand new... Im sure you can add more in parelle, but the box itself is full with i think 6 or so batterys.
how long does the battery last?
how many pics/MB on high res?
how long is the video capacity?
Would you have a airbox snorkle to fit a R33? If so, I'll take it :) How much?
PM me if you can please.
I have the snorkle, $50 for the airbox and snorkle :)
You still interested christian? Special prices for you cause you the SAU GOD!
$300 for all three amps, i really need cash thats the only reason im selling the amps...
Sorry i just saw this reply.
I haven't used it in a while, but it takes 4 batterys and you can fill a 32mb card with those 4 batterys. (does that make sence :P)
Pics are about 500kb on full res.
Not sure on the video, didnt take many of them.
If your interested, make me an offer.
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
