PLEASE CONTACT PAUL FOR MORE DETAILS ON THIS CAR: 0438 377 028
ENGINE :
2.7 LITRE
T88-34D TURBO ( HIGH FLOWED AND OVERHAULED )
HKS MANIFOLD
EXTERNAL WASTEGATE
N1 BLOCK
TOMEI PISTONS
TOMEI RODS
TOMEI CAMS
NISMO METAL HEAD GASKET
HKS VALVES
HKS VALVE SPRINGS
HKS VALVE GUIDES
HEAD PORTING
TOMEI TIMING GEARS
NISMO OIL PUMP
GTR33 BALANCED CRANK
JUN OIL BLOCK
JUN OIL BAFFLE
MILES OIL COOLER
ARC ALUMINIUM RADIATOR
CUSTOM INTERCOOLER PIPING
TRUST BLOW OFF
Z32 AIR FLOW METERS
APEXI AIR INTAKE FLUTES
CUSTOM OIL CATCH CAN
NISMO 720cc INJECTORS
GREDDY FUEL RAIL
NISMO FUEL REG
BOSCHE RACING FUEL PUMP
TRAIL SURGE TANK
POWER EXTREME 680x280x120 HUGE INTERCOOLER
TRUST 3” FULL STAINLESS EXHAUST SYSTEM
NISMO TIMING BELT
CAM COVERS AND PLUG COVER CUSTOM PAINTED
EXTENSIVE USE OF BRAIDED LINES
DRIVE CHAIN:
OS GEIKEN TRIPLE PLATE CLUTCH AND FLY WHEEL
OS GEIKEN CROSS RATIO GEARBOX ( 1st, 2nd AND 3rd )
CUSCO LSD
SUSPENSION:
TEIN COILOVERS
NISMO FRONT AND REAR STRUT BRACE
HKS UPPER LINK
MINES STABILISER
CUSCO PILLAR TENSIONER
BRAKES :
BREMBO CALLIPERS
MILES BRAIDED BRAKE HOSES
TOMEI MASTER CYLINDER STOPPER
NISMO BRAKE PADS
WHEELS
18x 10.5 DT-05 WHITE RIMS
NEW 235 x 40 KUHMO TYRES
ALLOY WHEEL NUTS
ELECTRONIC :
APEXI POWER FC AND COMMANDER
HKS BOOST CONTROLLER
HKS TURBO TIMER
BLITZ TORQUE CONTROLLER
ULTRA SPEED & REV DIGITAL METER
INTERIOR:
TOMEI 310 KM SPEEDO
BRIDE FIXED BACK RACING SEAT
HKS PEAK HOLD BOOST GAUGE
HKS EXHAUST TEMP GAUGE
GREDDY OIL PRESSURE GAUGE
GREDDY OIL TEMP GAUGE
GREDDY WATER TEMP GAUGE
GREDDY FUEL PRESSURE GAUGE
CARBON FIBRE DASH SURROUND
5 ZIGEN RACING STEERING WHEEL
FACTORY 10 STACKER CD PLAYER
EXTERIOR:
CUSTOM PAINT PROFESSIONALLY PAINTED BY DMD BRISBANE
NISMO BONNET LIP
NISMO INTERCOOLER AIR DUCT
THIS CAR HAS RECENTLY BEEN INSPECTED AT GAVIN WOODS WORKSHOP AND COMPRESSION TESTED ETC. ALSO HAS BEEN FULLY TUNED BY MATTHEW SPRY AT PITS PERFORMANCE TUNING.
$ 37,900
Edited by 07xtc
bump. why advertise if your not going to answer your phone. ffs
Hey guys Im paul the guy who owns the car. The car is definitely not an x drifter also empivian I cant understand why you say I dont answer my phone - I have never had a message from you on my phone and if I did I would I would ring you back immediately.
awesome gtr goodluck with the sale
how much power this baby putting out?
took it the track yet?
Havent taken it on the track yet . It made 450 HP at 1.3 ( safe tune )
has a balanced r33 gtr crank as in spec list
Sorry Paul havnt been on here to check the net. Been flat out with work.
I can say that this car is one of the nicest GTR's I have ever layed eyes on, top quality build. And I am not just saying this because it is a friend's car. I can honestly say that you wont ever be able to find a GTR and then modify it (to the quality that this is) the way this one has been modified and have any change left of twice or more than the asking price.
This car has hardly even been on the road since it came in from Japan let alone been drifted. It has been off to shops being modified, and having dollars spent on it! Paul imported this car and has imported several other high performance import cars (some of which are drift cars) so yes you will see his number spread across many forums.
Enjoy cleaning your underwear after going for a ride in this animal LOL
  • 4 weeks later...
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
