I have a stock R33 GTR, im running 14psi peak, but after a while (after hurting it quite a bit) the boost drops to 7psi peak!
Is this normal? Then when I turn the car off and let it cool down for lets say an hour, it will go back to running 14psi peak....
is this normal? Any1 else having this problem? Should I worry?
thanks!
https://www.sau.com.au/forums/topic/143031-boost-decrease/
Not normal but could be alot of things. Seeing it is in heat maybe its a flexible pipe sucking closed.. It'll either be a problem with boost control itself or a problem with getting the charge air to the engine.
Good luck :D
https://www.sau.com.au/forums/topic/143031-boost-decrease/#findComment-2667681
thanks!
I also have the same problem even tho its a 32 GTR, Be keen to find out also. I dont have a Boost Controller just removed the restrictor bung.
thanks
https://www.sau.com.au/forums/topic/143031-boost-decrease/#findComment-2667730
thanks!
I think you will find your computer ( stocker) cuts boost to actuator pressure because its leaning out up high to prevent engine damage .
You will find if you was running stock boost that wouldn't happen.
https://www.sau.com.au/forums/topic/143031-boost-decrease/#findComment-2672352
    • The real question is, on some of those wild roads they call highways, how many times did a farmer in an old ute from the early 2000s blaze past you over double lines?   Tassie is a wild and really cool place, and after doing a work related road trip there January of 24, I understand why Targa Tasmania is ran there, and is so tough to do well at! We had a brand new Camry Hybrid that handled quite nicely, and thankfully weren't in an old car, because cresting some of those hills in a 100kmh zone for it to suddenly be like "surprise f**kers, this is a recommended 30kmh hard right turn" wouldn't be pretty. We weren't racing the Camry around, but we weren't slouching in the bends either. But my lord those old farmers know their old clapped out utes, and those roads, as they were absolutely hammering it!   You're also super lucky to make it up to Mt Wellingtong this time of year. It's often road closed with snow/ice! Also, I hope you hit up Salamander Road in Hobart for some insanely good food (I highly recommend the dimly lit Irish pub for a Guiness Pie, or even the bangers and mash!!!)   How long did the Ferry take to get across? I want to do a road trip of Tas on my own time, but I get horrifically sea sick, and I don't want me on the Ferry, just the car 😛
    • So far so good, about 30km on it so far and nothing out of sorts yet thankfully
    • Look at @Kinkstaah's thread on the issue.
    • Hmm not really, I'd say its race car life or modified car life when you make 3 or 4 times the power Nissan designed the car for lol.
    • I'll let others with more breakage chime in, but I can't think of anyone who had a problem with the standard centre plate before they had a problem with the standard gears - the plate generally just gets replaced for safety when the gearset is upgraded. As for the gearsets, its not like they are OK at 600Nm and break at 601. Their longevity is a combination of how much torque you are making and how gentle you are on shifts (or not).
