dangerman4 Posted November 13, 2006 Share Posted November 13, 2006 where do you connect the solenoid wires on a r33 s1? i have read thru Pauls faq sheets but that doesnt tell me. from what he says it plugs in, but the plugs arnt even close to fitting, so do i have to chop an solder or what? Link to comment https://www.sau.com.au/forums/topic/143088-pfc-boost-kit-solenoid-wires-r33/ Share on other sites More sharing options...
paulr33 Posted November 13, 2006 Share Posted November 13, 2006 yeah just cut the wires it re-uses the stock boost solneoid wires its basically constant power and switched ground the switched ground runs to the ecu loom, wire 25 from memory Link to comment https://www.sau.com.au/forums/topic/143088-pfc-boost-kit-solenoid-wires-r33/#findComment-2666479 Share on other sites More sharing options...
dangerman4 Posted November 13, 2006 Author Share Posted November 13, 2006 yeah just cut the wiresit re-uses the stock boost solneoid wires its basically constant power and switched ground the switched ground runs to the ecu loom, wire 25 from memory how can it be constant power and switched earth if you say to high boost a standard car you ground the earth? if you have constant positive and constant (ground earth) then its going to be full open not opening and shutting 200 times a minute or whatever speed it works at? can you clarify for me? Link to comment https://www.sau.com.au/forums/topic/143088-pfc-boost-kit-solenoid-wires-r33/#findComment-2666501 Share on other sites More sharing options...
paulr33 Posted November 13, 2006 Share Posted November 13, 2006 the stock 33 solenoid is a open small width, open large width type solenoid, its not an open/close valve. the pfc boost kit one, the same as the avcr is an open/close valve, so it switches it on/off radidly to drive the boost pressure. the stock ecu and the stock solenoid switch the ground over 4500rpm to close it up a bit more, so the gate creeps a little to give some more boost pressure. the stock ecu and the pfc boost controll systems both use the same wires Link to comment https://www.sau.com.au/forums/topic/143088-pfc-boost-kit-solenoid-wires-r33/#findComment-2666561 Share on other sites More sharing options...
