  • Replies 65
Posted Images
ok to get this moving more info
on the car is a cat back exaust 3" in think cat back 5inch cannon
4oohp heavy duty cluch used
car is white
i have a radiator support for a nissan cefiro
1 green cefiro front bar
full interior perfect condition
left pasenger gaurd in green
bonet in green
full rear cradle
doors drivers side only
passengerside quarter glass
boot
looms
afm
coil packs
feul tank
can chop wotever u need off it being roof rear quarter panels not really fussed
2 or 3 standard headlights
driverside indicator
front and back seats
dash
dash cluster auto with 89,000km on it
steering wheel
engine crossmember
all switches and looms
lots more stuff cant think off now just ask
driver side guard is gone
carpet is gone
manual console is gone
pasengerside vent suround is gone
dash cluster suround with vents are gone
Edited by drftnfrysi
after the stereo surround, passenger dash large vent surround, centre air con vent assembley for to more of the passenger side of the middle...
also the 2 lil square things close to front windscreen on the dash
look im i get on this sit 1ce a week so
stop being an impatiient bunch of f**ks
my number is 0412938223
call me all ur questions
tail shft ill get back to u on a price
handbrake cover not worth the effort
of shipping it to adilade for how much it's worth
rear bars fine bit of exaust fumes but it's whit $140
i need the window regs for the front pasenger door
and rear driverside sorry
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
    • Wouldn’t touch par if they gave it to me. You need to ask how much power you’re looking to make and then add about 50% to it because that’s what you’ll end up making  The factory box says no more at about 350kw or so, the upgraded synchro boxes won’t handle much over 500kw for long and at that point you’re looking at an auto or dog engagement manual,  once you’ve gone dog engagement you may as well go sequential, they cost a little bit more but it’s worth it  also while you’re at it you should upgrade the transfer case with 10 friction plates
