WTB: Coil packs for R34 NA
OEM or Spitfire? whatever is available please let me know price as I would like to change this weekend..
Damn engine light is on and I've read this is a common problem
Let me know on 0433 978 565 (sms or leave a msg)
Thanks in advance
ill be needing some 17" tyers soon
a pair of 225 and 215's or 235 and 225's not to sure just yet as theyll be sticking outside the gaurds alittle.
i want a pair of each size not miss matched ones with legal tred.
cheers
Cheap girl-like car for my girlfriend, not me I swear :rofl:
Like something along the lines of a mid 90's model 4 cylinder
Hyuandai Excell, Lancer, Daewoo etc
Looking at the 2,500 mark
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
