Well i did a compression test today, and cylinder 1 is about 480kpa compared to the other cylinders of 780kpa. I put oil in the cylinder to form a seal to check if the rings were stuffed, but there was hardly any change in compression. So i'm thinking a valve or valve seat is buggered. If anyone knows of any other reasons why it would be low, i'm all ears! But either way, the cylinder head has to come off.
Where would i get replacement valves from if any are buggered?
Where should i get a head gasket from?
What should i look out for? I'm tipping that setting up the Timing again will be the main challenge. I'll get a new timing belt while i'm at it.
I just hope i'm not getting myself into something more than i can handle!
What would i be looking at dollar wise to pay someone else to do it?
Cheers,
Andrew
https://www.sau.com.au/forums/topic/14388-cylinder-head-removal-any-tips/
Guest DrDrift
Its pretty bothersome taking out a CA head, not too sure about skylines. I took the head off together with turbo and intake manifold (2 ppl). Brought the head to a builder and have tested on valve leak. It best if you get copper head gasket, good investment. If you have the right tools and have specs like torque to apply on head bolts then its pretty cheap doing it. I paid $200 for grinding the head surface, valve leak test, pressure test etc. Another $200 for Nissan Gasket kit which includes head gasket, exhaust gasket, intake manifold gasket and valve steam seal. I am not sure how much will they charge for change valve seals. So total for me is less than $500. I have got quotes from a fairly low pricing mechanic, $1000 is the min for a 4 cyclinder.
Hope that helps
Tip 1, Ensure you remove the 3 - 10 mm bolts before undoing the headbolts 2 are at the back of the head 1 is at the front near the vcc solidnoid.
Tip 2, remove the power steering pump bracket as it has 1 bolt that go's into the head also,
Tip 3, get yourself a long 10mm allen key socket for the head bolts or you will need to remove the camshafts.
Tip 4, setting up the timing is easy if you put the motor to TDC before removing the cambelt. With the belt cover & cas removed and the motor @ TDC you will see a dot on the cam wheel's that lines up with a mark on the back of cambelt cover.
(the back half one still bolted to the head.)
Tip 5, These tip's should see you right but they are in no pictular order.
2 hour two remove bout the same to replace (with the right tools) but hard to say it all depens on what happens read: bolts breaking/siezed ect....ect.
I dont think you could get into too much trouble even if you give up after removal of the head and toe it somewhere would still save yourself $ on some labour.
so i'll say 2 days to remove... lol
What are the main tools that i'd need?
I spose i can always tow it to DrDrifts place, and get him to finish it for me if i get stuck!... hehehe, i'd be demoted from head mechanic to floor hand passing spanners etc :P
10 12 13 14 mm spanners
8 10 12 13 14 mm sockets 1/4" drive and ratchet
10 12 13 14 mm scokets 1/2 " drive and ratchet
extension bars & uni joints for both 1/4" & 1/2 " drive
10mm allen key socket 1/2" drive & breaker bar
pliers & cutters
Torque wrench
Philips & flat Screw drivers size's 2 & 3 of each
a small flat jellwers srewdriver (for the wire clips on some plugs)
Telescopic magnet (for dropped bolts / screws)
oil/water catch pan
set of small allen keys
Leaver bar
I think thats about it.
Cool... i have all that stuff except the 10mm Allen key socket 1/2" drive.
I'm debating on whether i should pull the head off or hasten my engine build! Cos if i pull the head off and there is a cracked ring landing or something then i'm stuffed... no engine to use in the car! Ideally i want to whip the head off, replace any damaged vavles and put the head back on, drive around with a bit of performance and take my time with my other engine build... but nothing is ever ideal!!! hehe
normally if youve got damaged valves ie bent or something then they wont seal with the seats and youll have 0 compression. if youre leaking some compression then its usually bottom end damage. ultimately the only way youre going to be able to figure it out is to take the head off
i did it for the first time ever a couple of weeks ago. took me 6 hours off and 4 hours on. it isnt too hard and setting up the timing is easy, just make sure you keep tension on the PS belt otherwise youll have to remove the raidator shroud to undo the bottom cover (pain in the ass)
good luck
if it's bent i can understand that... but if it's just not seating correctly cos of a burnt valve or seat then wouldn't it drop the compression? The little booket that came with the compression tester says that's the case... but then i spose who's really to say, and like you pointed out, the only thing that will answer the question is to taking the head off! The engine is running fine, it's not rattling or making any funny sounds so that's why i'm thinking valve. I spose if i take the rocker covers off i can check measurements, (can this be done with hydraullic lifters or is it different). Maybe somethings come loose and just needs adjusting?! lol... now i'm clutching at straws.
  • 8 months later...
  • 3 weeks later...
I NEED SOME HELP ASWELL!!
I have removed inlet manifold and turbo from exhaust.
All head studs have been loosened from the cams, the center is a pain in the ass :wassup:
i have snapped tools ect and they still wont loosen any suggestion on how to remove these center studs :)
U need:
10 mm hecs piece that's long enough to fit down to the bolts...I bought an L-Shaped one (because I couldn't find any other), and cut the end of it off (so I had one straight 10mm hecs bolt). Stuck that in a 10mm socket, attached that to a breaker bar piece, added a few extension pieces (so I had an arm about 50cm long - the more leverage the easier it is), and with a little effort, they came out. It's just the initial cracking of the thread that's difficult.
If you don't have a breaker bar, you could use a ratchet on the 10 mm piece with a metal pipe over the handle of the rathet for extra leverage.
Best of luck...
If you need any more help u can email me and I should be able to reply fairly promptly.
Cheers,
Michael
I pulled these settings down from someone's post when I did my head gasket:
These are for an RB20DET (i don't know if it's the same for a 'DE')
______________________________________________________________
Head torque settings
These are the specs I used on my own last rebuild as supplied by Hytech engines
Head is torqued down in 5 stages.
1. 22ftlbs
2. 72ftlbs
3. slacken off
4. 22ftlbs
5. 75ftlbs or 90o
Engine torque setting
Main bearing torque 40ft/lbs
Big end bearings..... also 40ft/lbs
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
    • Unsolicited advice? Keep the engine as close to stock as you can. Nothing wrong with adding some boost and making a little more power, but given where you are, you really don't want to try to make it into a monster. I can't imagine the roads are up to it, and the lack of locla support when it grenades will be a ball ache. FWIW, If there is a dyno around that you can access, then brand new injectors are a good idea, which will lead you to (at least) putting a Nistune in it, which will allow you to put an R35 AFM on it, all of which will make it possible to make it much much nicer to drive and live with.
