Your Choice
29 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
  • Replies 167
so can we decide for the 11of feb then..are you all keen to do the zigzags in the hills???if not i wont add it to the map??? the twisties might be interesting with the stageas especially seens we will have to do 3 point turns to get around??
there will be plenty of two lane roads, lights and hill roads and of course the chocolate factory stop mmmmm :/
It all sounds good from here...
Just hoping like buggery that I will be able to get the transfer case issues sorted by then.
I really dont think the zig zag will be a problem with the stags.
from what was written before ppl were saying the 11 cause of the weekend ppl going away and having other commitments etc.
lets make the official stagea cruise on the 11th of feb...YES???????? NO???????
LIST OF LOCATIONS OF CHRISSIE LIGHTS (ASKTED)
http://www.askted.com.au/askted/displayCon...HouseAddresses/
LIST OF LOCATIONS IN THE LIGHTS COMPETITION ON SEVEN
http://7perth.com.au/view/2/20061204160728/
xmas lights cruise and bring the kids :) one night before xmas i say, would be good fun. im unsure how to find all the good light locations but i know theres a crazy street in connolly absolutely full of lite up houses.
yeah that cul de sac is awesome!! some nice ones down in woodvale too .... im up for a cruise now :/
jus seen those links ... xmas lights cruise ftw!!!!!!!
Edited by STAGE-A
well i was thinking of a start at 10ish??? at south street.. that way we should be at whitemans for the bbq at lunchtime
this "cruise" will be more a drive then the last :mad:, cause the last was a meet and greet not really a cruise :P
So, a question from a newbie (planning to drop in to Hyperdrive from the boonies & catch a cruise at the same time) to see if I've waded through the decision making process correctly? Cruise date is 11/02/2007, etd is 10am, route is towards Choc factory the back to a bbq location by mid-day for feeding the kids? South street starting point is the Perth city job? I'm guessing there are a few in Perth metro area?
Yep - sounds like you managed to sort the wheat from the waffling just fine. Looking forward to seeing you there (and having a decent look at a 260RS in the flesh :) )
BTW, Kristie - thanks for the chrissy lights cruise idea. The kids loved it and want to make it an annual thing.
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
