  • Replies 612
  • 1 month later...
  • 3 weeks later...
  • 1 month later...
Chrisssy Brown - Forever.........................................................................
'ah its time to relax and you know what means, glass of wine, your favourite easy chair and a-course this compact disc playing on your home stereo. So go on indulge yourself, thats right kick off your shoes, put your feet up, lean back and just enjoy the melodies, after all music sooths even your collapsing colon'
Edited by Topaz
Sounds like a BIT of Offspring "Smash" to meeee
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
