What would you like to know? I need to sell my, you want to buy one.
Genuine V-Spec, 1995 model, 75,330km.
Owned for over 2 years, regularly serviced with only best parts and components,
Makes over 270kw at all 4 wheels (with dyno sheets).
No cheap mods.
White Nismo 320km Dash & Gauges, Clarion CD head unit with Aux input for I-Pod.
I have receipts for most items and work was done by well known work shops.
It currently makes over 270awkw with dyno sheets.
Geniuine reason for sale as priorities have changed. Genuine tests welcome.
Call Brad 0402 207 386, or Email [email protected]
Car is currently missing lower lip from front bar as it was damaged on a friends driveway. I have lowered the price acordingly.
*Am still very negotiable and price only reflects esthetics.*
Some mods include:
Group A turbos.
Apexi power FC.
Apexi AVC-R boost controller.
Trust twin entry 115mm thick intercooler.
HKS Hyper Drager exhaust.
Bee-R racing front pipe.
Hi-flo cat.
Trust oil cooler with remote oil filter.
Redline oils in gear box, transfer case and diffs.
Endless brake pads.
Tinted windows.
Above mods are for "off street use only" officer :P, as car will be supplied with standard computer/boost controller and quite exhaust (Always go to have and would highly recommend!)
If you want a cheap and easy way to get into a GTR, give me a call, as with the money you save from this cheap price you can replace the missing front lip with either Genuine, aftermarket, series 2 or even a 400R style bar. The choice is yours.
Edited by BMCGTR
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
