I'm 100% stock...
I had considered air shocks as a possibility for a while. (Adjustable ride height)
currently want (one day in the distant and modified future) tein edf.
And technically - 'lines already have coil overs. Its just the setup of the shock in the spring (or so I understand - go ahead, kill me if I'm wrong...)
--ebola
I'm 100% stock...
--ebola
incase you have the wrong idea, the Tein EDFC only controls damping...not height.
Yeah, but since I actually want to push my car hard once in a while, they are probably better. same height, perhaps, but can soften them off for road & tighten them for track (for when I get there...)
race quality air shocks... I couldn't find out if they were height adjustable - and as for air bags, well, although triple convolute bags have the right amount of travel (and legality), they are a 'street' application (afaik).
not that I get to the track (once so far), but I will one day.
sumone in Perth had those in a civic....I went to the same pannel beater where the guy did his panelwork....the panelshop owner said that the suspensions are too soft buoyance....not very nice to drive in
http://www.airbagit.com/airsuspension.htm
http://www.air-suspension-forum.com/
c/o http://www.google.com/
answer to your question is 'no'. Short reason is "airbags don't handle well" long reason is "do research". air sounds all good, but in practice, its just not worth paying for (I still intend to keep using it, but only for combustion and respiration)
If you could find a set that can 'handle' ... and is cheaper than proven technologies, awesome. I doubt it, though. Oh - and just a thought - you might want to look at upgrading things like sway bars as well at the same time.
EDIT - just looked at the air-suspension-forum link. damn its empty. time to remind myself "research != google".
Edited by ebola
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
