yeah thanks for the input, but as i said, it is for my bf's car, and whether he NEEDS it or not lol, he WANTS it :D , so it makes choosing a christmas present that much easier for me....yay
And as far as him loving me for it...yeah lol, that will be the day. He's never even told me i look pretty :) .
Thanks for the replies guys you have been so helpful. i've ordered the greddy in the silver...so i'll let you know if he likes it or not...i will probably give it to him before christmas so he can have fun installing it.
The shift lights, i dont think he likes the 'pro' with the 3 lights...he reckons that the two warning lights would be useless...anyone have any thoughts? what is the benefit of them?
But i have to say, the pro is my favourite, i reckon it looks pretty cool personally...hmm
then kick him to the curb. then you won't have to waste money buying presents that he doesn't need.
as for turbo timers, if you thrash the car then just pull up, you make think that you are doing good by leaving the timer on, but there is little air going through the radiator, the brakes are sitting in the 1 spot, putting all their heat into the 1 spot. you are best off doing a lap around the block driving normally so that cool air goes through the radiator, and the brakes can cool down.
well with the pro the 3 lights come on in stage as you approach redline. so if redline is say 8000rpm you would have 7700rpm 1st light, 7800rpm 2nd light, 7900rpm all 3 lights. so basically they just give you a little more time to react. but if he doesn't like them just get the M. it's cheaper anyway :D
i completely understand what you are doing. guys, stop trying to disuade her from buying a turbo timer for her boyfriend. he wants one. she wants to buy him a gift. let's leave it at that.
if my girlfriend wanted a hermes hand bag for christmas. I'm not going to suggest a plastic shopping bag will do a better and cheaper job. I'll just buy her the handbag and know that she likes it.
and you should make your boyfriend tell you that you're smoking hot at least once a day. or else forget turbo timer shopping, start man shopping! haha (jokes).
    • That's not a transistor --- it's marked ZD1 which makes it a zener diode. As to what the breakdown voltage is, not enough there to divine.
    • Hi all, Long time since I've posted here. Looking for some advice on what I can remove to further identify the cause of my issues.  I can move the passenger seat forward and back but the knob used to adjust the seat angle is pretty much free spinning, there's very little resistance.  Removing the side cover I can see that the chain is intact but the shaft for the adjustment spins without the gear attached to it moving.  What's my next step for disassembly here? Is this a common fault? Just being a little cautious as I didn't want to start removing bolts for a spring to fly out or something equally as stupid.  Cheers
    • The incentives are mostly the same, yes. Ethanol is cheap compared to the cost of doing 98-100 RON with crude oil alone. 87 to 93-94 AKI all with E10. In 2020 Canada mandated E10 as a part of their "renewable fuel standard" and is supposedly going to go to E15 in 2030. In California where there are only 8 refineries with two threatening to shut down next year it's been over 20 years now of E10 and 91 AKI maximum because there's just not enough refinery capacity or crude oil supply relative to the demand for premium unleaded fuel. And CARB's low carbon fuel standard means functionally none of the diesel available at the pump is made from crude oil anymore. It's almost all entirely 20% biodiesel blended with 80% renewable diesel (hydrotreated vegetable oil) now. The number of gasoline vehicles that support E15 or higher ethanol concentrations is surprisingly low, I can't imagine it being wise to play tricks like this without flex fuel sensors in most of the fleet.
    • It's almost certainly the same as the one next to it. Have a fish around amongst these hits https://www.google.com/search?q=surface+mount+transistor+m33&sca_esv=9cb49794e0b2005d&source=hp&ei=2vJ5aNjTB7Kw0PEPldnS8QM&iflsig=AOw8s4IAAAAAaHoA6qkfmF6XcygtrZ4Vu9f92NXF_RFd&ved=0ahUKEwjYqIPP7MWOAxUyGDQIHZWsND4Q4dUDCA8&uact=5&oq=surface+mount+transistor+m33&gs_lp=Egdnd3Mtd2l6IhxzdXJmYWNlIG1vdW50IHRyYW5zaXN0b3IgbTMzMgUQIRigATIFECEYoAEyBRAhGKABMgUQIRigAUjKCFAAWABwAHgAkAEAmAHfAaAB3wGqAQMyLTG4AQPIAQD4AQL4AQGYAgGgAuYBmAMAkgcDMi0xoAfMBLIHAzItMbgH5gHCBwMyLTHIBwU&sclient=gws-wiz
    • South Australia, which is hardly as far behind as the rest pf Oz makes out, and who is also not a paragon of progressiveness (read that as over-legislation) in the area of vehicle standards, has this to say on the subject: Adjustable coil-over suspension Aftermarket adjustable coil-over suspension components are suspension units that incorporate an external thread on the main body and corresponding threaded spring saddle that allows the vehicle's suspension height to be varied. If fitting aftermarket or coil-over suspension components you must submit an Application to modify a light motor vehicle form and a report from a light vehicle engineering signatory (LVES).
