G'day guys.
These are from Import Car Parts Plus in the USA.
GB: START 06/12/06 ENDS 24/12/06
What i found was a easy to use Electronic Boost Controller, that im going to order. Price is Excellent
Here's all the info on them - make sure you read all of this cause it'll probably answer all your questions.
PIT BCU Boost Controllers -
The all new BCU+ (boost controller unit) is the first boost controller to feature multiple stages of boost, a built-in turbo timer, boost guage, voltmeter, and two 12 Volt outputs. P.I.T. uses the latest technology to give the user multiple ways of controlling and monitoring boost levels. With High and Low stages of boost and adjustable gain, you can tune the boost to switch depending on track or road conditions. The BCU+ also incorporates an Automatic and Manual Turbo Timer to let your engine cool down after a run. By using the electrical Outputs you can use the BCU+ to control any 12V DC source, like a nitrous kit and/or intercooler spray. Know exactly what's going on with your engine by using the Last Boost and Voltmeter settings on the easy to read LCD screen.
To keep the price down, I need to order 10 units.
How to get onto this great deal"
You can do direct deposit into my account then I'll express post them to you after they arrive. Both ways are fully tracked so they won't go missing.
Express post cost an extra $15 nation wide.
Cost Price of the PIT EBC is $310 + $15 Freight
This gb will end in about a month or before if we can get the numbers.
Ordering To order a EBC, just put a post up here or you can PM or send me an email at [email protected] with your details.
Feel free to ask me any questions.
Also this is a price break i was given if more than 10 pairs are ordered.
10 - 15 pairs $295
15 - 20 pairs $285
20+ $275
So who wants to start the list.
LINK ON PRODUCT : also note there pricing is in US dollars
http://www.sportcompactonly.com/performanc...x?c=160&b=9
http://www.performance-trends.com/boost_controllers.htm
1) R33KID *IN
https://www.sau.com.au/forums/topic/146227-pit-electronic-boost-controller/
these look pritty good, and all in one. damn.. oi i might be in on this, just going to read up a bit more on them.. small soliniod. i wonder how accurate the readings are on the screen.. any one used one of these before, awesome price for something like this as well!
Edited by seriesII
that solenoid is good for 25psi
sweet, thanx for that. would you be able to buy a upgraded solenoid from them if i needed to go above 25psi?, that you have seen?
Edited by seriesII
  • 1 year later...
Hi guys, I have one of these EBC's and I'm struggling to get it to hold boost.
I wonder if it is a problem with the product or if the START boost & GAIN settings might have something to do with it?
I've tried ajusting the values for each, but still no luck.
If anyone has managed to tune one of these controllers effectively, your setting details would be appreciated!!
P.S. I've installed it on an R34 GT-T (completely standard).
Cheers.
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
