Got 2 head rest monitors (Chinese make)
Brand new and come with mounting brackets.
Come with remote controls and all that is needed to install.
paid $299ea
Asking $250 now just $150ea
located in sydney
can post anywhere in oz at buyers expense
willing to swap for pc or phone
Edited by DANSR33
https://www.sau.com.au/forums/topic/146308-7inch-head-rest-monitors/
any specs at all?
High resolution LCD screen
Adjustable Image brightness/colour and contrast
On screen menu display
Adjustable upper and lower visual angle
2 way video input, V1 and V2
Left and right angle adjustable
  • 3 months later...
  • 3 weeks later...
  • 1 month later...
what brand are they?
they are hard to sell because you can get a monitor on ebay for nothin thesedays... and it will be a piece of poo
people need to know brands so they can confirm retail prices.
I already quoted they have no brand name, just the model number...
thanks for letting me know why they arent selling... :cool:
    • Also seen this as an option
    • I get you, we’ll see I’m aiming for 200ish kw now and hopefully 300rwkw down the line after some upgrades maybe like headstuds, E85 flex fuel etc  so trying to make it final for that now, I can get a GTT airbox for $280 so it’s not too bad but not sure if there’s better ways to spend that money. I seen online they say pod filter which isn’t enclosed isn’t good especially for a plus T.      hard to say what to do
    • Meh. How much power can you make from a +T anyway? I wouldn't have though it would be enough to challenge the airbox. It's not as if it's tiny compared with the turbo one. As to putting a pod in a stock airbox .... it's not the filter element that would be restrictive. It would be the air inlet to the box that would be the narrow point, which you could open up regardless of what element was inside. On my R32 I opened up the sort of triangular opening in the bottom front corner of the box, deformed (heated, moulded) some 4" stormwater pipe to fit to that opening and punched a 4" hole down through the inner guard to the spot where the stock intercooler used to be. This was purely in the search for a cold intake, but you could do something similar if you need to open up the inlet side of it. The AFM tube size is the same for both NA and turbo, so the outlet from the airbox is same same anyway. If you're going to do the right thing, then an aftermarket ECU won't care about the AFM (ie, you can get rid of it). But even if it was still there, people pull >300rwkW through them all day, and I suspect you won't be going there.
    • R34 RB25de Neo by the way ^
    • Doing a +T on my car and I’ve read the precious forums lots of mixed reviews from sometime back.  checking if anyone has any ideas for airbox or enclosed pod filter or solutions?  I was thinking stock GTT box but some say it’s restrictive? I seen some people try fit in a pod in the box anyone done that recently?  not any good enclosed options ? Thanks
