Fuel Pump Problem - Weird Priming Noises On Cold Start, Fine Once Warmed Up?
Hey all,
Have a small problem regarding the Bosch 040 pump since installed. On a cold start when I turn the key to reds/ignition the pump makes weird noises when priming. Instead of the usual buzzing/whirring it makes weird knock like noises, reminds me of my friends description of indigestion noises. It sounds like it works, stops, works, stops, works stop giving off a knocking noise.
The noise however doesn't occur anymore after you've driven the car for abit i.e after its actually warmed up. Once the car is warmed up it'd make a normal priming noise of a constant buzzing for a few seconds then just stop.
Any ideas of what this could be? I'm hoping direct feeding a 13.8v power source to the pump will solve this issue.
Oh and when I installed the pump I warpped the pump in a rubber layer so it wouldn't make any noises, could this potentially be causing the problem or another problem?
Thanks!
Andy
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
    • There's restrictor pills in the stock boost control hoses. That's how they set the amount that was bled off and hence the "high" boost setting. The usual mod in the day was to remove it and send the "high" boost setting up to about 14 psi.
    • Thanks Duncan, that's the best info I've read. Furthermore after learning about the PCM programming side controlling the factory boost solenoid, the purpose of the solenoid is to "bleed" boost when pin 25 is earthed, thus allowing spring pressure in the wastegate actuator to overcome diaphragm boost pressure, thus closing or reducing the position of the wastegate flap creating more boost as the turbo is able to spin faster. It's pretty cool to see a designated Pill to do exactly this, would have liked to have seen it with a tiny filter over the end for those moments in vacuum.  The constant bleed pill has now been removed completely from the system and solenoid boost control has been restored once again.   Case closed 😂
    • The wideband reading is meaningless if it's not running. Why are you using shitty old sidefeeds on any engine, let alone a Neo? What manifold and fuel rail are you using to achieve that? Beyond that, can't help you with AEM stuff as I've never been their ECU/CAS combo.
