G'day Mick,
hey wayne,
Three questions
Where did u get this from?
How much?
Much quieter than a canon?
Is it more restrictive than the canon?
cheers mick
Where did u get this from?:
Bought & fitted at Kirrawee Mufflers
http://www.kirraweemufflers.com/
How much?:
Both Kirrawee & Best Mufflers quote $500 for this specific model.
I originally ordered the single pipe oval for $400 - they couldnt get me one straight away so they offered me the dual pipe version for the same price :D I'm glad I ended up with the dual pipe, looks much more stock.
Much quieter than a canon?:
Definitely quieter than the cannon I had fitted, or at least has a lot less bass.
I also replaced the large resonator I had for a hot-dog type, this would affect it as well of course.
The new muffler is still fairly loud when the valve is fully open, I had a mate take it for a drive past me and it did sound very nice indeed.
Is it more restrictive than the canon?:
Yes, no question at all - I did go from a 3.5" to 3" for starters. Theres no way it could be as free flowing.
I'd love to put it on a dyno again (was dyno'd only 3 weeks ago) just to see the numbers.
I've done quite a few 0-160 tests since buying the car, and with the new muffler I am honestly hard-pressed to notice any significant difference. I do think that the turbo is spooling up a little higher in the rev range though... I think! Not much in it if it is :D
At least now I feel a lot safer going past the cops, it looks standard and I can turn the bugger down if need be.
Cheers
I would go Apexi N1
its really quiet when you want it to be, but produces a very clean note when you giving it some pin. That said, its not what i would call a loud exhaust at any rpm
Could be an option?
Thats the thing - until you see and hear any given muffler hooked up to the same kind of car as yours, its hard to know what you might find too loud or not loud enough.
I've been having evil thoughts about constructing some kind of solenoid activated valve that simply diverts/opens up the pipe before the resonator :D I'm sure I'm not the first to have thought of that though! Would be nice to have for the times when you really want maximum performance...
Got my twin dump pipe from these guys... The said that there twin tips have same flow as there cannon and look at there power figures...
Good quality and price give them a look http://www.cesracing.com.au/products/
agreed, R spec that is one nice lookn r34.
theres always something about red cars lol.
i recommend u get the r34 gtr diffuser on the front aswell, because it sitll looks a little short in size.
and we all no the wing has to go =]
how much did the front conversion set u back? did u get it from powerplay?
    • Agreed, and in particular the earth strap that should go from the subframe to the chassis but it often broken or left off. There is a section in the R32 workshop manual you can follow for troubleshooting if you don't see anything suspicious, and depending where you are (there is no location on your user profile) you should be able to get your hands on a second hand replacement unit still if needed
    • Yeah they mention as a R34 for 2.5 Turbo...but then again thos "small" were also for R34 by that different site. But i look into it and that 310mm EBC is for R34 GTT. And by those you linked the specs are the same 🙂    EDIT: I found these on one site here: DBA 4000 series T3 DBA42304S They are 310mm...and it says are for R34GTT...are there good? EDIT2: ok they have pads too.  What "color" should i get for street use? I dont want/need some noisy ones...(and if they are not that dusty that is good too)
    • Yeah, shame. Maybe  driver's carpet is available 🙏. I am waiting for both amayama and nangun to confirm.
    • Probably. I take it that they are also mentioned to be for R34 Skyline? For example.... RDA has that part as RDA7957. I have the dimpled and slotted version of that on my car https://www.ebay.com.au/itm/285518478694?srsltid=AfmBOopKxMuAFpsxZJdB1cam4D5RAj1f9yJyOttPZLAwXVNCOiwlhrIy This is DBA's top one piece equivalent https://www.ebay.com.au/itm/364246686631?srsltid=AfmBOorbb0XHQgqTvZLgQPhg70nqJtGvdojKnugum3O2LFSr2h-obp8D
    • Ok i will get those 310mm. I found one but on a different site. This is the description on those...is it ok? Technical parameters: - Axle: front. - Disc type: ventilated. - Number of holes: 5. - Disc diameter: 310mm. - Total height with center: 54mm. - Thickness (new/min.): 30/28mm. - Designed for brake calipers manufacturer: Sumitomo.
