Now thats what I call a great story!
Absolutely immaculate cars and I am sure Todd is really pleased the N1 is with you Terry. Given all the subtle hints he gave at Tech Night, he still wants that car!
My all time favorite (and dream) car is a Nur. And Matt's ride is the epitome of it!
Sent from my iPhone using Tapatalk 2
I have to tip my hat to these great photographers Dimi like Dan, Matt, Kory, Eric and co...
Eric in that photoshoot in the hangar, was often telling admirers where else to stand since their reflections were interfering. And of course, he was using 3-4 fill in R/c flash units at a time.
Ensuring that the black LMGT4s were lit up adequately was always a problem. I think Matt Everingham and Kory Leung have mastered that issue well!
  • Like 1
I didn't want to insert the word "filthy" - but that comes with whoever the owner is. :P
Srsly, I like the shadows (of the front vents) generated by the angle of the lighting.
...reminds me of the testarossa fins' shadows at the right angle.
:laugh:
