I got a Turbosmart plumback bov for sale no longer needed.
top part of bov has two spots where oil cooler braided lines have rubbed against it leaving two grooves. Besides that works fine.
looking for quick sale $150
prefer melb pick up
cheers
Edited by SKYLNR
https://www.sau.com.au/forums/topic/147261-sold/
    • New CAS just turned up from NZ Wiring. Looks like a nice bit of gear.  So, yeah. Triggered, bro. Realised I may as well do the cam belt while mucking about with it so will order one of them.
