  • Replies 45
I took the heat shield off to get the photo. I would just like to know for sure what it is. Even if i know whether it's stock or whether it's not is good enough for me. Nick from APC said it was aftermarket but didn't know what it was...but he was looking with the heat shield on. So who knows...
https://www.sau.com.au/forums/topic/14734-turbo-id/#findComment-299978
Hi MM2, the high flowed R33 RB25DET turbo on our R32 GTST RB20DET says "16V 5 Nissan Motor" on the compressor cover.
I have seen a number of R32 GTST's with R33 GTST turbos fitted, so this may help if yours is another one.
https://www.sau.com.au/forums/topic/14734-turbo-id/#findComment-302258
OK, i managed to read what i think it says on the compressor cover with one of those little mirrors on a rod (don't know the name of it). Reading clockwise around the cover it says:
M27 (with a circle around it) 2 1-1 A/R 80 (i think) GARRET.
Any ideas what turbo it could be?
Regards,
Scott
https://www.sau.com.au/forums/topic/14734-turbo-id/#findComment-302582
My 2510 has M27 and .60 cast onm the front, it also has a machined front with 4 allen key nuts on the front. I don't think yours is stock, as it doesn't have the factory 90 cast section from the compressor cover on it.
More pics would help
https://www.sau.com.au/forums/topic/14734-turbo-id/#findComment-303329
only akin 150rwkw it aint gunah be anything huge
firstly put on a heat shield though, thats gunah be boiling the engine bay as it is
the actuator is in the std position
i have a 0.60 comp housing and it rubs against the chassis rails so judging by that pic it aint that big...
id dare say from size and power output its either a small GT series turbo or a high-flow.
easiest way to find out is pull the intercooler piping off and take some better pics for us
also if the car hasnt got a front mount (or theres no evidence of it ever having one ie cut up front supports or front bar) then i doubt its anything huge
https://www.sau.com.au/forums/topic/14734-turbo-id/#findComment-303661
    • So could it be assumed it has been installed intentionally with potentially a power FC boost controller kit?
    • Had my rig on Matt's dyno at PITS the other day. After a few years between tunes I added a few sensors and swapped intercoolers. Result. 553hp at 26psi. Not bad for an FJ20 that was built in 2007. The problem.. It filled the overflow bottle on hard runs which leads me to believe the head gasket isn't sealing. I have a coolant pressure sensor which was reading cap pressure at 22psi and occasionally overrunning to 23/24 psi on deceleration after a pull. It was not spiking. It has arp2000 head studs and a cometic gasket. As its been 18 years in service, I pulled the engine out and head off. Everything looks good but we obviously have an issue. Where I'm at.. Years ago I had the same issue, I checked the stud tension and they were all over the place. Some at 60 to 70 and some up near 90. I nipped them all to 100ft lbs and this stopped the water push until now. I believe this compromised the gasket back then. What do I do? 2 options are..  1) I bought arp 625+s, which I could put in with a new gasket. Thinking Kameari this time, reassemble and try again. 2) strip the block, get fire rings machined in with copper gasket and try that. I do not want to push it more than 28 to 30psi. I think the turbo will be out by then anyway. (G30-770). My other concern is the long term ability of a copper head gasket. Are they streetable for years? I feel like a new gasket with the new studs will probably suffice, but I don't know. Any thoughts welcome and advice on copper gaskets and fire rings. Thanks!
    • I'm a fan of the JZX110, and the Aristo. Big cruiser cars, and with the factory cars, super comfortable and feel like you're driving an armchair! And the JZ motors are a pretty nice engine too, especially with some basic mods.   The import process, and the need to be able to trust people, and the fact there's so many scammers around is what ever puts me off wanting to go through that ordeal!
    • I don't care for these at all, but at least the underside looks straight and not rusty. A good basis for a long life. Many cars from Japan have been lifted with forklifts and f**ked almost irrepairably.
    • Yes, but it's not dumb or dodgy. You can build a perfectly good boost controller from a pressure reg, a relief valve (looks same same as a reg if all from Norgren or SMC, for example) and a check valve. I ran one for years. Only superceded with  EBC because I could get one for cheaps and wanted finer control.   THis mod is certainly not a sketchy boost mod, provided the boost is kept below the "spin to death" threshold of the turbos.
