Hi all as title states.
I am selling my full titanium cat back exhaust from R32 sedan. Very light and in great condition with NO major scratches or dents.
This is a japanese exhaust so quality is excellent.
It is quite loud and is awsome on the track. It is a 3 and 1/4 inch straight pipe with 4inch cannon.
850 ONO
https://www.sau.com.au/forums/topic/147400-titanium-exhaust/
