i,ve been reading this thread very closely, and have just about done everything here. bought a high flowed turbo(same as the pics last page) had no problems with boost on my stock turbo, set at 12 and dropped to 10 as all bleed valves do. thought id chuck on the high flow and set it to 12 to 13 psi as i still had stock injectors. went for a tune and went to 12, leveled and slowly climbed to 17 at the end of the rev range. since then i have remover the turbo and machine out the waste gate hole from 24 to 28 mm giving me a 36% increase in surface area, didn't work. had a 2 1/2 " split pulse dump pipe that i modded to a bell mouth, didn't work. got rid of the dump pipe and put a 3" bell mouth front/dump pipe on, didn't work. swapped actuators, didn't work. removed the bleed valve completely and put it directly onto the standard tapping point, didnt work. i am now about to go the other way and put a 2" restriction plate in my exhaust to see if that rectifies the problem. the car has been detuned to 230hp at the moment so i dont pop anything.
i am running a safc2, full 3" exhaust (only restriction is the cat).
  • Replies 68
Posted Images
I now can say that i solved my boost issues once and for good. I was beginning to doubt my actuator too. I bit the bullet and bought a brand new Gizzmo MS-IBC and what a diff. Super easy to install and tune. Tuning took me just around 10 mins. Just have to fine tune it now but i did that on the motoway to work this morning :ermm:
Boost comes on super quick compared to the stock actuator. Rock steady 7psi to the redline. Sorry but i have to suggest an ebc. Just out of curiosity, have you tried one at all?
Trust me, i thought i had a "too free flowing" exhaust as well but its not.
ok, just fitted a 2" restriction plate between front pipe and cat. took the car for a blast and sat rock solid on 7 psi (have taken bleed valve out and gone from standard tapping point to waste gate). waiting for car to cool down and will fit a 2 1/4" and see what that does. will keep updated!
ok, 2 1/4 with no bleed gave me 10 psi. re fitted bleed valve(set at 12 psi) and went to 12.5 @ 7000 in 2nd. my problem looks like too much flow through exhaust. booking in to get full tune next week and hopefully around the 300 rwhp figure?
Good one mate! Im happy you got that sorted out!! :)
I got the ebc for $240 from modyoucar.com.au when they had the special. Over here in nz, it retails for around 5-600! so i got it for half price inc delivery.
Just out of curiousity, hows your torque curve? Whats your peak torque and at what rpm?
When i had mine stock, with just a catback and a pod, it made 330-340 Peak and over 300Nm from 2200 onwards.
  • 3 months later...
And i still say its rubbish :(
Not one person i know has had a problem here in Vic, and R33's are a dime a dozen
actually we have seen this problem on the dyno a few times , had a rb25det with front mount and good flowing exhaust suffer from this problem , even removed the actuator and opened the flapper valve all the way and loaded the car up on the dyno still made 13 psi of boost and tapered off to 12 at 6000 rpm , explain how and different actuator will help when the gate opening(hole) is physically not big enough to get rid of gases (also this vehicle made 200 rwkw on 12psi with stock turbo)
regards,steve
    • I've looked up the parts number (41011AL501). It's around $700 OEM. Usually our Infiniti G35 here in Canada have interchangeable parts with my Stagea but the parts number are not the same. I have looked around and it seems the JDM 2005 V35 Skyline (which is the same as our G35) has the same caliper but I cannot confirm. And I can't find a repair kit. The inner brake pads drags on the rotor, seems to be rusty piston. Thanks for the info by the way
    • This coupled with 6-9 speed autos with ridiculously short gearing is why these modern shitbox cars always seem so fast off the line. If it wasn't for those things, Raptors would not seem fast. The problem we have is there is a driveability gap between a more gentle take off and a wheelspinning sideways launch. The difference between ankle flex required to achieve one and ankle flex required to achieve the other is about 0.5°.
    • Yeah I think I'm also with the opposite here. It's 'hard to keep up with traffic' because in the real world I'm accelerating with 15% throttle and they are pinning it. It feels like I'm being an overt dickhead at anything above 15% throttle, so the car sounds like I'm being an overt dickhead to keep up with/get ahead of traffic when I'm really just trying to drive with traffic. There would be no issue 'keeping up with traffic' if we used the same level of throttle input/aggression to drive around. People really do just drive around with their foot nearly pinned in econoboxes.
    • To be fair it's the other way around. 300kw is boring in a modern Golf or BMW. They are so competent / well-engineered / devoid of emotion that you have to go stupid fast to feel anything. Whereas the <300kw RB still makes all the right noises and it feels good to drive. Can pull off at the lights with the turbo whooshing and the blow-off pssshing and feel like the coolest kid on the block. Just don't look to the side where you'll see the bored housewifes in their shitbox Yaris/Corolla/Camry that kept up because you didn't go fast at all
    • 300kW is so boring in a Skyline, you'll get spanked by someone's mum's Golf with Alibaba pipes, and an email tune.
