  • Replies 376
Posted Images
haha... sounds like the route we'll be taking mr moo!
cool it's an awesome drive. we did it in the wet last time still fun but some scarey sections when its wet
is this just skylines or can any car come along?
Might be working that day :(
But ill do my best to make it !!!
Hehehe someone has to kick your ass again through the twisties :)
hmm ill ask hitman to come out again !
you, mr tumnus, HAVE to come :P sif miss out on our annual cruise!!!!! you have plenty of notice, so work around it ;)
ooo!!! yesss! i'll let him know! hes probably the only one (out of you and him) that will beat me!!
OOOOoOoOoOOOOOoooooooo
:miner:
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
