My 32 4 Door Drifter - Stadium Drift Pics And 3071r Pics * Check Last Page*
  • Replies 156
I bought a navara drive brand new from nissan, then knocked the roll pin out the body, pulled the shaft out and melted the cog off with an oxy, i then took the 33 cog off the 33 drive and modified the shaft to fit this cog (you cannot use the navara cog) basically the 33 cog has a half moon cut out on it, so i ground a half moon onto the shaft and then placed the cog on, drilled a hole in the base and put a roll pin in, then put the complete shaft back into the navara body and put the roll pin back in there.
easy process!
As for my clutch its a brand new exedy 5 puck....
haha yeah seems to work.
we ive got quite a lot of work ahead of me to get the car ready for G1 coming up... got to change the clutch with anoither new one, make sure thats all sweet, then remap and full dyno tune, wheel alignment, and fix up a couple of suspension issues lol.
fun times.
damn straight!!! im hoping for a good result as the car is performing very well now, Loads of torque, loads of grip, good tyres and wheel alignment... all thats left is the driver needs to make it happen hahaha
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
    • I assume clearances were all a-okay?
