Hi guys, just noticed in "The Great Atheism Piefight" that Kozeyekan quoted Hungryhippo and I but somehow the attributions came out arse about. It's on page 17.
Don't think he would have tried to do this on purpose and can't see how he could anyway. Possible software glitch?
https://www.sau.com.au/forums/topic/147973-attribution-of-quotes-bug/
Ok, he quoted Hungryhippo and I using the standard quote feature. The funny thing is that the note that gives the source,date and time
at the top of the quote frame (when it comes up in the final post) was arse about in this case.
Hippo's quote came up as being originally posted by me.
My quote came up as being originally posted by him.
It's a weird one. Haven't seen it before.
I'll put up links to make it easier for you to check.
This is the relevant page. Have a look at the eleventh post from the top.
In it I mention reading one of Tragic's links.
Two posts down from mine Koyezekan uses two quotes and my words come up as being originally posted by Hippo while his words come up as being originally posted by me. :laugh:
http://www.skylinesaustralia.com/forums/in...2631&st=320
Thats what im thinking.
I've never had issue with the quotes.
If you are manually typing them, which he might be... then thats how its going to get mixed.
If your really worried, send a PM to Kozeyekan... as to me the issue is more user related the forum bug/software
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
