hey i have a R33 s1 standard turbo for sale purchased as i thought mine was blown but it has turned out to be valve guides damn it! So now i have no use for the turbo i bought it's in good condition told it came off a car that had done 70xxxkm reliable bloke :)
purchased for $350
after quick sale need cash to fix head $300
pm
email [email protected]
mob 0420243038
Edited by Darkon
https://www.sau.com.au/forums/topic/148299-r33-s1-turbo-for-sale/
been to the mechanic and ran on the dyno, it's only really blowing smoke under deceleration the after that which means the guides are worn and under pressure it suck oil into the intake system causing it to blow plenty of smoke FARKEN GRR
as for price i really would like to get 300 i only just bought it for 350 and that seems to be every ones firm price so i thought 300 should be the goods pm a genuine offer and i can always consider it
can supply elbow and lines now if required (have someone i can get them off)
price drop without lines and elbow $250 for just the turbo
COME ON IT'S A BARGAIN!!!!!
Edited by Darkon
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
