1: Check the buyers guide for plenty of info on what to look out for when buying a stagea found here: http://www.skylinesaustralia.com/forums/in...showtopic=92065
2: I would be getting a mutual mechanic to do a compression test, ie: One that you choose, not the dealer!
3: The auto gearboxes in these stags and a very strong bit of gear, i and a quite a few other people here in melbourne have over 150kw at wheels in our stags and have not had a drama with our boxes, providing like others have said you maintain them ie: bigger auto cooler (very cheap and inxspensive upgrade, keep the auto fluid topped up etc.)
4: Check for rust, inside the door where the mirror is mounted just near the door trim at the (mine has a little bit of rust there, but lucky for me no where else that i can see. In the buyers guide it also explains where else you might find rust.
5: There really is not much else to say, they are a great car and i am extremely happy with it, i have had mine for around 5 months now and have not had a drama, i service mine every 5000 kms and my mechanic reakons its in as new condition. Parts are very easy to find if its mechanical or steering and suspension components as majority of it is skyline gear: Radiator, motor, brakes, suspension and there are so many parts from skylines that can be upgraded on the stags if you find it hard to find parts for them.
Panels: Will be your only problem if an unexpected accident occurs, but if you are fully insured then you really wont have much to worry about.
Personally for a Series 2 i think that it is a reasonable price especially considering its in australia already.
Yeah that one looks pretty good, honest kms on it, get an inspection done and if it's been looked after go for it. 133k ain't "high" kms, the engine should still be perfect if it's been serviced properly.
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
