Hey all,
If you're looking for some fat wheels without having to go 5 stud, then these are for you...
Came off my S15 fronted sil. Rears will fit with some flaring.
Work VS-XX - Finest 3 piece Modular Construction, Super Lightweight wheels with reverse outer rim.
4 hole - 114.3 PCD
18x9.5JJ off +19 - Toyo Proxes4 225/40ZR18 Tyres - 90% tread (slight camber wear on inner edge)
18x10.5JJ off +19 - Trampio Guwn 245/40ZR18 Tyres - 80% tread
These tyres alone are worth big coin...
One wheel has a small section of minor gutter rash, the rest are basically flawless except for some small light, scratching (normal wear basically). Awsome condition!
The fronts have a good 70mm worth of dish and the rears, 90mm!
Come with all 4 Work centrecaps.
All wheels have recently been balanced.
$2,500 FIRM
Located in Adelaide, SA.
Can deliver to your door anywhere Australia wide for $100!!
PM with any questions/queries.
Edited by driftKNG
Hey all,
Tyres are sitting around doing nothing so it's time to go...
Here's the rundown:
16s
- 4 x BRIDGESTONE TURANZA ER30 - 205/45R16 - 70% - SOLD
17s
- 2 x BRIDGESTONE POTENZA RE050A - 215/45R17 - 70% - $100
- 2 x BRIDGESTONE POTENZA G3 - 255/40ZR17 - one at wear indicator, one with 2mm+ indicator - $50
18s
- 2 x PIRELLI PZERO ROSSO - 255/40ZR18 - 60% - SOLD
- 2 x BRIDGESTONE POTENZA RE040 - 235/40ZR18 - 70% - SOLD
- 2 x BRIDGESTONE POTENZA RE040 - 235/40ZR18 - 50% - SOLD
- 2 x SILVERSTONE FTZ SPORT EVOL 8 - 235/40ZR18 - 1 BRAND NEW /W NIPPLES, other 95% - $300
Will not be taking pictures. - Come round and check em out if interested. Prices are firm.
Cheers!
Edited by driftKNG
- 2 x BRIDGESTONE POTENZA RE040 - 235/40ZR18 - 70% - $100
- 2 x BRIDGESTONE POTENZA RE040 - 235/40ZR18 - 50% - $50
I'll take these off your hands. Today if you're available. Would like to inspect them first so if I could get your address that would be sweet! I'll PM you too.
cheers mate
How much to ship the 2 pirelli pzero 255/40/18 to sydney?
Also, I am keen on the gram lights, but why only 235's on them?
Great looking wheels and GL with the sale !
I just wanted to know what courier company you use to get :
"Can be delivered to your door ANYWHERE Australia wide for $100!!"
I ve got a set of wheels i need shipped across the country and I'm in need of some advice, if u can help ?
PranK - It will cost you $65 to have these sent to your door in Sydney... Unfortunately there is a minimum charge associated with items of this nature. >_<
I put 235's on the Gram Lights because I feel this is the best profile (looks wise) while still maintaining drivability. Anything more stretched on that width starts to get a little dangerous. Suits these wheels perfectly!
:laugh:
Edited by driftKNG
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
    • Unsolicited advice? Keep the engine as close to stock as you can. Nothing wrong with adding some boost and making a little more power, but given where you are, you really don't want to try to make it into a monster. I can't imagine the roads are up to it, and the lack of locla support when it grenades will be a ball ache. FWIW, If there is a dyno around that you can access, then brand new injectors are a good idea, which will lead you to (at least) putting a Nistune in it, which will allow you to put an R35 AFM on it, all of which will make it possible to make it much much nicer to drive and live with.
